but if i want to add this ext in my main forum, what need to do install it succesfully without error?
3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Ultimate Points Extension
Re: Ultimate Points Extension
Thanks to dmzx for the fixed problem
If you didnt install previous version it will install ok.ivailo95 wrote: 20 May 2018, 12:03 thanks to dmzx for the fixed problem
but if i want to add this ext in my main forum, what need to do install it succesfully without error?![]()
seacoast
I'm looking for the change log for 1.2. Where can I find it? Also, will this update 1.1.8 and run on 3.2.1 without issue?
Thank you!
Thank you!
Venatus Vinco
While this is being worked on...is there a way, or future option, to make user points transfer records public (or at least view-able by mods)?
Thanks!
VV
Thanks!
VV
EaglesTruth
This extension is still not working with me. I keep getting the same error as soon as i enable it....
And before anybody tells me i need to delete the data in my database tables, I do this manually everytime. Because it wont let me un-enable the extension. I have to manually remove the points tables and stuff and then delete the folder via FTP. Please can someone help me with this problem.Fatal error: Uncaught phpbb\module\exception\module_exception: CANNOT_REMOVE_MODULE in /home/eagles7814/public_html/phpbb/module/module_manager.php:448 Stack trace: #0 /home/eagles7814/public_html/phpbb/db/migration/tool/module.php(420): phpbb\module\module_manager->delete_module(235, 'acp') #1 [internal function]: phpbb\db\migration\tool\module->remove('acp', 'ACP_CAT_DOT_MOD...', 'ACP_POINTS') #2 /home/eagles7814/public_html/phpbb/db/migration/tool/module.php(454): call_user_func_array(Array, Array) #3 [internal function]: phpbb\db\migration\tool\module->reverse('add', 'acp', 'ACP_CAT_DOT_MOD...', 'ACP_POINTS') #4 /home/eagles7814/public_html/phpbb/db/migrator.php(714): call_user_func_array(Array, Array) #5 /home/eagles7814/public_html/phpbb/db/migrator.php(683): phpbb\db\migrator->run_step(Array, false, true) #6 /home/eagles7814/public_html/phpbb/db/migrator.php(436): phpbb\db\migrator->process_data_step(Array, Array) #7 /home/eagles7814/public_html/phpbb/db/migrator.php(288): phpbb\db\migrator->try_apply('\\dmzx\\ulti in /home/eagles7814/public_html/phpbb/module/module_manager.php on line 448
PM me Admin account and board details.EaglesTruth wrote: 25 May 2018, 06:41 This extension is still not working with me. I keep getting the same error as soon as i enable it..
Upload the 1.2.1 version to your board and i will set it correct.
You see them in "Logs" or do you mean something different ?Venatus Vinco wrote: 25 May 2018, 04:11 Hello,
Thanks!
VV
seacoast
Thank you. ;)
Can I update from 1.8 on phpbb 3.2.1 without losing data?
seacoast
Ok sounds good! Thank you.
See PM to try it
Venatus Vinco
Maybe I am missing something: users can see their own logs, yes. But I am looking for a way for mods/public to see logs or a transaction history.
Thanks. Sorry if I am not being clear or if this function already exists and I am missing how to activate it.
VV
seacoast
Ok. I'll have to wait until next week when I have some time. Thanks again. I'll let you know how it works for me. :)
Seems that 'ACP_POINTS' translation is missing in common.php ?
I see this on viewonline.php: ACP_POINTS
Same here:
Same here:
