3.2 & 3.3 Extensions Database 3.2 / 3.3Ultimate Points Extension
Extension Name: Ultimate Points Extension
Author: dmzx & Posey
The Ultimate Points is an addition to your phpBB3 forum, where people can gain points and also are able to spend points, of course.
- Add get_top_balances() to the stable third-party API.
- Migrated the entire extension from the legacy $this->user->lang['KEY'] pattern to the standard \phpbb\language\language service.
- Refactored the UCP controller (ucp/ucp_ultimatepoints_module.php) to controller/ucp_controller.php.
Duel/Wager
Challenge another member to a 1v1 wager. Both stakes are held in escrow the moment the challenge is accepted, so the pot is always there for the winner. Choose how the outcome is decided:
- Coin-flip — resolved instantly and automatically, server-side
- Moderator decision — a mod/admin with the new permission picks the winner from a dedicated queue
New permissions:
- u_use_duel — use the Duel module (granted to Registered by default)
- m_resolve_duel — resolve admin-decided duels (not auto-granted; assign explicitly). A mod/admin can never resolve a duel they're a party to.
New ACP settings: min/max wager, accept time limit, max open challenges per user, default resolution mode, mChat announcements — under Points → Duels.
Other:
- Full duel history in UCP
- Expired pending challenges auto-refund
- New dispatcher events: duel_challenged_after, duel_accepted_after, duel_resolved_after
Bounty Board Post a task with a reward attached — the reward is escrowed the moment you post it, so it's guaranteed to be there once the work is done.
Another member claims an open bounty and submits their work
- Optional poster approval step (ACP toggle) before payout, or instant payout if approval isn't required
- Poster can cancel an unclaimed bounty (refunded); claims that sit unsubmitted past a configurable time limit are auto-released back to the pool
- New permission: u_use_bounty
- New ACP settings: min/max reward, claim time limit, require-approval toggle, mChat announcements
- Full bounty history in UCP
- New dispatcher events: bounty_posted_after, bounty_claimed_after, bounty_paid_out, bounty_cancelled_after
- PHP 8.2+ compatibility fixes, public API facade (core/api.php) for other extensions to hook into
- Add email notifications.
- Code clean-up.
- Short syntax code.
- Code updates.
- Language file added for ACP.
- Code clean-up.
- Code update for permissions.
- Code update for auto groups.
https://www.dmzx-web.net/viewtopic.php?p=25660#p25660 available.
- Code update for 3.3.x
Added ACP options to post message in mChat.
Code update.
Fixed ACP clear logs.
Added more info to information screen.
Added Bank name and Lottery name to various templates so name will change also.
Set permissions correct.
More code updates.
Added more options to ACP settings.
Added Font Awesome icons.
Code update.
Code update.
Code update.
  2. Unzip the downloaded release, and change the name of the folder to `ultimatepoints`.
  4. Copy the `ultimatepoints` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/ultimatepoints/composer.json
  6. Look for `Ultimate Points Extension` under the Disabled Extensions list, and click its `Enable` link.
RTI kartname
Re: Ultimate Points Extension
Post by RTI kartname »
It works on 3.2.0?
RTI kartname wrote: 21 Jan 2017, 22:10 It works on 3.2.0?
Yes this topic is for 3.2.x
RTI kartname
Just installed on my forum tst 3.2.0
:sad:
Clear the cache if yoou have no access then open ftp and then clear the cache folder (or do it within your hosting account)
RTI kartname
Did not work the same, however, I realized that lacks a module
Joost
Post by Joost »
I have the same error as i open the Point settings. :wtf:
Fatal error: Uncaught phpbb\exception\version_check_exception: Connection refused in /home/vhosts/hpmagicworld.nl/httpdocs/phpbb/version_helper.php:266 Stack trace: #0 /home/vhosts/hpmagicworld.nl/httpdocs/phpbb/version_helper.php(231): phpbb\version_helper->get_versions(true, false) #1 /home/vhosts/hpmagicworld.nl/httpdocs/phpbb/version_helper.php(210): phpbb\version_helper->get_versions_matching_stability(true, false) #2 /home/vhosts/hpmagicworld.nl/httpdocs/ext/dmzx/ultimatepoints/includes/version_check.php(67): phpbb\version_helper->get_suggested_updates(true) #3 /home/vhosts/hpmagicworld.nl/httpdocs/ext/dmzx/ultimatepoints/controller/admin_controller.php(531): dmzx\ultimatepoints\includes\version_check->check() #4 /home/vhosts/hpmagicworld.nl/httpdocs/ext/dmzx/ultimatepoints/acp/acp_ultimatepoints_module.php(41): dmzx\ultimatepoints\controller\admin_controller->display_points() #5 /home/vhosts/hpmagicworld.nl/httpdocs/includes/functions_module.php(676): dmzx\ultimatepoints\acp\acp_ultimatepoints_module->main('\\dmzx\ in /home/vhosts/hpmagicworld.nl/httpdocs/phpbb/version_helper.php on line 266
kaspir
Post by kaspir »
Looks like I had to sacrifice old version data to get it to work.. nvm.
Check out phpBB contributions & extension downloads. :P
RTI kartname
Finally it seems to work :eusa_dance:
kaspir
Post by kaspir »
RTI kartname wrote: 22 Jan 2017, 15:17 finally it seems to work :eusa_dance:
1.1.8? Beeecuzzzz I just downloaded twice, and WinRaR is telling me the archive is corrupt. I can't even decompress it. Sorry. :(
Anders wrote: 23 Jan 2017, 09:02 can confirm this and there is more downloads that is corrupt :eyes2:
Thx for confirming!
Yea I too tried other downloads, clearing browser cache, restarting. Something wrong mate, I DL from an ext quick from phpbb.com just now fine.
Anders
Post by Anders »
Can confirm this and there is more downloads that is corrupt :eyes2:
Download in first post fixed.
Joost
Post by Joost »
Thank you , it's works.
I see not my navigation, all links moved to the quick links... :wtf:
Yes if you downloaded from the first post as thats a temp download.
