3.2.x Extensions Database 3.2 / 3.3Navbar 3.2.x
Navbar 3.2.x
Extension Name: Navbar 3.2.x
Special thanks to: martin & Sniper_E
Extra navbar select menu use dmzx_navbar_quick_links as event to add the links.
Change language file to whatever you want the call the navbar menu.
See "Games" menu in navbar here.
Navbar 3.2.x v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `navbar`.
  4. Copy the `navbar` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/navbar/composer.json
  6. Look for `Navbar` under the Disabled Extensions list, and click its `Enable` link.
Re: Navbar 3.2.x
dmzx, martin and Sniper_E Thanx U :tumbsyes:
awr
    Mac OS X Safari
Re: Navbar 3.2.x
Post by awr »
Turkish Language Pack
tr.zip
infspirit
Re: Navbar 3.2.x
Post by infspirit »
Spanish Language Pack
Re: Navbar 3.2.x
Dont know how to use it then see here Navbar
Re: Navbar 3.2.x
German language file
Tastenplayer
Re: Navbar 3.2.x
Post by Tastenplayer »
I'm probably too stupid - I installed this extension yesterday at my local testboard.
But I do not find out how I can paste the links in this extension? Where I must edit it? I will make some radiolinks inside. Because there is no good radio extension until now.
Be the best version of yourself rather than a bad copy of someone else!
Excuse me for my English, but I learned it by talking with people, not in school.
Re: Navbar 3.2.x
To add some links use the dmzx_navbar_quick_links as an event.
So rename for example overall_header_navigation_append.html from an extension where the navbar link is in to dmzx_navbar_quick_links.html
then the link is shown into the menu.
Tastenplayer
Re: Navbar 3.2.x
In this case , I must have also installed the navbar quicklinks extension?
Re: Navbar 3.2.x
Tastenplayer wrote: 06 Feb 2017, 21:07 In this case , I must have also installed the navbar quicklinks extension?
The extension in first post you need to install for this.
ninouee
Re: Navbar 3.2.x
Post by ninouee »
Thank you for this extention :mml:
cs.dk
Re: Navbar 3.2.x
Post by cs.dk »
dmzx wrote: 06 Feb 2017, 20:57 To add some links use the dmzx_navbar_quick_links as an event.
I don't get it.
How do you actually use this extension?
I would like my regular quick links at the navbar, ie. unread posts, own posts, etc.
Re: Navbar 3.2.x
There is a character missing, an "s", it has to be dmzx_navbar_quick_links
Re: Navbar 3.2.x
Scanialady wrote: 04 Mar 2017, 23:44 there is a character missing, an "s", it has to be dmzx_navbar_quick_links
Posts and quotes fixed well spotted.
Donald123
Re: Navbar 3.2.x
Post by Donald123 »
great :cool:
Thank you for this extention :thumbdown:
