<span class="qte-attr qte_31_32-qte">3.1.x & 3.2.x</span>
Posts: 6617 Joined: Jan 13th, '14, 20:45
Post
by dmzx » Aug 16th, '15, 14:31
Extension Name: Special title
Author: dmzx special thanks to
This extension allows users to add a special title in UCP to their username.
Permissions can be set by group.
[travis]dmzx/Special-Title[/travis]
updated URL to viewprofile
docblocks update
Twig update
Service.yml update
Add ACP option to change title.
Download the latest release.
Unzip the downloaded release, and change the name of the folder to `specialtitle `.
In the `ext ` directory of your phpBB board, create a new directory named `dmzx ` (if it does not already exist).
Copy the `specialtitle ` folder to `/ext/dmzx/ ` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/specialtitle/composer.json
Look for `Special Title ` under the Disabled Extensions list, and click its `Enable ` link.
capalex65
Posts: 12 Joined: Aug 16th, '15, 05:24
Post
by capalex65 » Aug 16th, '15, 19:42
Any chance you could add that admins can edit the title from the ACP?
Post
by dmzx » Aug 16th, '15, 19:47
capalex65 wrote: Any chance you could add that admins can edit the title from the ACP?
Will check for that option.
capalex65
Post
by capalex65 » Aug 16th, '15, 20:46
I also noticed, that it doesn't show up on the memberlist viewprofile, only in viewtopic, and the board list.
Posts: 5139 Joined: Apr 6th, '14, 14:12
Post
by martin » Aug 16th, '15, 20:51
capalex65 wrote: I also noticed, that it doesn't show up on the memberlist viewprofile, only in viewtopic, and the board list.
member list
capalex65
Post
by capalex65 » Aug 16th, '15, 21:47
martin wrote: capalex65 wrote: I also noticed, that it doesn't show up on the memberlist viewprofile, only in viewtopic, and the board list.
member list
As i said. It doesn't show in Viewprofile.
capalex65
Post
by capalex65 » Aug 16th, '15, 22:05
I know. I should've formulated myself better. I was referring to the page that shows up, when you click someones name. It's from the memberlist.php file, with the mode viewprofile. That's what I meant. Sorry if I was confusing.
uruguayito
Posts: 120 Joined: Jul 2nd, '15, 17:40
Post
by uruguayito » Aug 17th, '15, 13:06
Thanks for this ext
Sorry for my bad English.
I'm a latin american man.
Spanish is my language.
Post
by martin » Aug 17th, '15, 13:58
Your like the next version.
Post
by dmzx » Aug 18th, '15, 13:17
New version see first post.
Posts: 348 Joined: Dec 13th, '14, 01:40
Post
by Solidjeuh » Aug 20th, '15, 18:22
Dutch language file:
nl.zip
Post
by dmzx » Aug 20th, '15, 18:23
Solidjeuh wrote: Dutch language file:
nl.zip
thanks!
playgoods
Posts: 40 Joined: Oct 6th, '15, 06:45
Post
by playgoods » Oct 8th, '15, 13:37
I cannot get this to show.
I'm on 3.1.6
I set permissions so only admin can use. When I set it to show next to my admin username nothing is shown
Post
by dmzx » Oct 8th, '15, 16:04
playgoods wrote: I cannot get this to show.
I'm on 3.1.6
Do you use also username image together with this extension
