3.1.x Extensions Database 3.1 / 3.2Your post count
Your post count
Extension Name: Your post count
Author: dmzx / martin
Shows number of posts counts in quick links.
dmzx/Your-post-count
downloadsystemcat?id=41
  2. Unzip the downloaded release, and change the name of the folder to `yourpostcount`.
  4. Copy the `yourpostcount` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/yourpostcount/composer.json
  6. Look for `Your post count` under the Disabled Extensions list, and click its `Enable` link.
