Posts: 6502 Joined: 13 Jan 2014, 21:45
Post
by dmzx » 27 Jul 2015, 01:16
Extension Name: Forum Icons
Author: dmzx special thanks to
Add forum icons, simply click on the icon to set the forum image.
Note: Upload all forum icons in
images/forumicons
- Twig update.
Changed upload path to
images/forumicons so when disable extension the links are not broken.
Add selected image
Icon Package:
forum_icons_package.zip
Download the latest release.
Unzip the downloaded release, and change the name of the folder to `forumicons `.
In the `ext ` directory of your phpBB board, create a new directory named `dmzx ` (if it does not already exist).
Copy the `forumicons ` folder to `/ext/dmzx/ ` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/forumicons/composer.json
Look for `Forum Icons ` under the Disabled Extensions list, and click its `Enable ` link.
Post
by dmzx » 27 Jul 2015, 09:41
Update version see Update version 1.0.1 · dmzx/Forum-Icons@5522744 · GitHub for changes.
Posts: 348 Joined: 13 Dec 2014, 02:40
Post
by Solidjeuh » 12 Aug 2015, 00:46
Love this extension!
There is just 1 line missing in the language file
( btw, my screen resolution is showing wrong in this topic, I have 32" screen.. 1080p full HD )
Post
by dmzx » 12 Aug 2015, 00:55
Solidjeuh wrote: Love this extension!
There is no
'FORUM_IMAGE_EXPLAIN' in the code so I can recall, and logout and login again to the forum so the resolution will be adjusted.
Post
by Solidjeuh » 12 Aug 2015, 01:03
Hmz that's strange, cause the code was in the acp..
Maybe a leftover from phpbb 3.0
Ok resolution works now :)
Post
by dmzx » 12 Aug 2015, 01:05
Solidjeuh wrote: Hmz that's strange, cause the code was in the acp..
Posts: 5135 Joined: 06 Apr 2014, 16:12
Post
by martin » 12 Aug 2015, 01:15
Regards to screen size Purge all sessions needs to be done so every one has to login to reset there cookie.
uruguayito
Posts: 120 Joined: 02 Jul 2015, 19:40
Post
by uruguayito » 12 Aug 2015, 18:44
Thank you very much
I love it
Sorry for my bad English.
I'm a latin american man.
Spanish is my language.
large
Posts: 5 Joined: 24 Aug 2015, 12:48
Post
by large » 26 Aug 2015, 07:50
Excellent extension, thank you for making it.
nelflucifer
Posts: 70 Joined: 03 Jan 2016, 12:24
Post
by nelflucifer » 03 Feb 2016, 18:58
Need help!! I decided to add soy PNG pictures 547 pieces. So here's what happened:
what's the problem?
Can be in a file name with a space? For example: "my picture" - right?
Post
by dmzx » 03 Feb 2016, 20:17
nelflucifer wrote: 03 Feb 2016, 18:58
what's the problem?
Check the url of the image and see to what path it will look
nelflucifer
Post
by nelflucifer » 06 Feb 2016, 10:45
dmzx wrote: 03 Feb 2016, 20:17
what's the problem?
The path is the same and where were the original pictures (the ones that go by default with this extension) that is,
ext/dmzx/forumicons/forum_icons/xxxxxx.png
