3.1 & 3.2 Extensions Database 3.1 / 3.2Screen resolution in viewtopic
9 given 1
Extension Name: Screen resolution in viewtopic
Author: dmzx special thanks to martin based on the code of 4seven.
This extension shows Screen resolution in viewtopic.
Cookie based so logout and login again on your forum.
dmzx/Screen-resolution-in-viewtopic
downloadsystemcat?id=34
  2. Unzip the downloaded release, and change the name of the folder to `screenresolution`.
  4. Copy the `screenresolution` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/screenresolution/composer.json
  6. Look for `Screen resolution in viewtopic` under the Disabled Extensions list, and click its `Enable` link.
Taka51
    Windows Vista Firefox
Re: Screen resolution in viewtopic
Post by Taka51 »
Thanks Dmzx
Here is the translation in French
Good late afternoon
WebDvdBdR - Page d’index
9 given 1
Taka51 wrote:Thanks Dmzx
Good late afternoon
Thanks added :thumbup:
playgoods
Post by playgoods »
It's not working.
I purged cache, purged sessions, refreshed browser, logged out and in. It shows the text screen resolution but no actual setting
9 given 1
playgoods wrote:It's not working.
Send me test account from your board.
tamarin
Post by tamarin »
I have the same problem.
Can you help me please?
Thx.
PS: I sent you the test account from my test forum via PM...
spazz
Post by spazz »
Same here as well, phpbb 3.1.6, php 5.5.9, Ubuntu 14.04 server
1 given 1
Unitsall the ext delete the data now change the styles/prosilver to styles/all and see if that works.
spazz
Post by spazz »
No effect.
1 given 1
Out of interest what theme are you using and is it up to date ? if its out of date the event maybe missing (i doubt it is tho)
spazz
Post by spazz »
Using default prosilver.
I did some mild debugging and it is as if
{postrow.USER_RESOLUTION}
{L_SCREEN_RESOLUTION}
are not getting any value.
The first one seems to be an empty value, and the second one returns the string:
Screen Resolution which does seem right, so it is firing appropriately.
btw Thank you for the fast reply.
spazz
Post by spazz »
Looks as tho it is not writing to the database.
Looking further. If I find the cause I will gladly share as I see others have this too.
1 given 1
Is your database mysql ? if not what are you using and il make a database of the same type and test.
spazz
Post by spazz »
My dev setup is xampp on windows with mysql and production is mariadb.
Both have the same issue.
Prod:
dev:
1 given 1
Ok that kills the database type then i use mysql on xampp win 10 (works) also mysql on zorin (ubuntu)
think il change table types and test.
