Extensions Database 3.2 / 3.3 ⇒ 3.2 & 3.3 Browser & OS in Viewtopic
3.2.x & 3.3.x
13 given 1
Extension Name: Browser & OS in Viewtopic
This extension shows browser icon and OS icon in viewtopic.
Works with new made posts and older posts will be indicated like this Image untill you edit the post.
- Changed code to core/functions.
- Changed browser/os functions.
- Code cleanup.
- Update service.yml
Added Windows 10 and Spartan browser
Older posts are indicated like this:
  2. Unzip the downloaded release, and change the name of the folder to `browsericon`.
  4. Copy the `browsericon` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/browsericon/composer.json
  6. Look for `Browser & OS in Viewtopic` under the Disabled Extensions list, and click its `Enable` link.
1 given 1
Re: Browser & OS in Viewtopic
If by any chance you was clever enough to hard code this old 3.0.X mod into 3.1.X then delete the edits you did (pm me for the modx file if needed) leave the sql in the database :wink: upload the ext install it then go to old posts and all your browser and OS icons are still there.
If by any chance you did have a few posts that had no icons then your see the unkown icons just make an edit to give them posts some.
dsaf
Post by dsaf »
Error on mine and enabling in ACP:
Return to the index page
General Error
SQL ERROR [ mysql4 ]
Duplicate column name 'user_agent' [1060]
SQL
ALTER TABLE `egcn_posts` ADD COLUMN `user_agent` varchar(255) NULL
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 855
CALL: trigger_error()
FILE: [ROOT]/phpbb/db/driver/mysql.php
LINE: 181
LINE: 329
CALL: phpbb\db\driver\mysql->sql_query()
FILE: [ROOT]/phpbb/db/tools.php
LINE: 1428
CALL: phpbb\db\driver\factory->sql_query()
LINE: 1809
CALL: phpbb\db\tools->_sql_run_sql()
LINE: 802
CALL: phpbb\db\tools->sql_column_add()
CALL: phpbb\db\tools->perform_schema_changes()
FILE: [ROOT]/phpbb/db/migrator.php
LINE: 550
CALL: call_user_func_array()
LINE: 496
CALL: phpbb\db\migrator->run_step()
LINE: 305
CALL: phpbb\db\migrator->process_data_step()
LINE: 202
CALL: phpbb\db\migrator->try_apply()
LINE: 185
CALL: phpbb\db\migrator->update_do()
FILE: [ROOT]/phpbb/extension/base.php
LINE: 80
CALL: phpbb\db\migrator->update()
FILE: [ROOT]/phpbb/extension/manager.php
LINE: 187
CALL: phpbb\extension\base->enable_step()
FILE: [ROOT]/includes/acp/acp_extensions.php
LINE: 179
CALL: phpbb\extension\manager->enable_step()
LINE: 674
CALL: acp_extensions->main()
FILE: [ROOT]/adm/index.php
LINE: 81
CALL: p_master->load_active()
Please notify the board administrator or webmaster: dsafdonotreply@dsaf.co.uk
Powered by phpBB® Forum Software © phpBB Limited
1 given 1
WHat are you enabling in acp ?
dsaf
Post by dsaf »
The ext.
Added it to the ftp, click enable, takes me to the next screen to enable again.. and then crashes.
13 given 1
dsaf wrote:The ext.
Looks like you already have the 'user_agent' column in your database.
Check this in table posts.
1 given 1
did you have any form of icons installed befor ?(hard coded) or old database but updated ?
Are you trying to get me to login as you and peek ? :rolling:
EDit posted at same time.
dsaf
Post by dsaf »
I dont think i've tried to install this at all since upgrading to 3.1.* It was all fresh...
You can if you want.. :eyes2: :rolling:
1 given 1
Small fix
Open ext/dmzx/browsericon/includes/user_agent.php
line 170
return '<span class="user-agent" onclick="alert(\'' . utf8_htmlspecialchars($description) . '\')">' . $result . '</span>';
return '<li class="user-agent" onclick="alert(\'' . utf8_htmlspecialchars($description) . '\')">' . $result . '</li>';
Now it will be valid
if you want a pop up with even more info in it then replace it with this
return '<li class="user-agent" onmouseover="alert(\'' . utf8_htmlspecialchars($description) . '\')">' . $result . '</li>';
Note if you get fed up with a pop up just tick the check mark in the pop up and it will revert back to the original way of working.
rammstein
Post by rammstein »
how do to enabled in the profile I have both? ? but how I can change and also for member
thank you
hello
comment on fais pour activé dans le profil j'ai les deux ? ? mais comment je peut change et pour les membre aussi
merci
13 given 1
rammstein wrote:hello
thank you
hello
merci
Dont know what you mean, you can enable only the extension in ACP.
rammstein
Post by rammstein »
Ok j'ai trouvé il faut juste faire un nouveau poste sa marche
merci
ok I found it just make a new post his walk
thank you
1 given 1
Enable the ext after installing then make a post it only shows in topics so you wont see it in the profile page the only place it shows is in the mini profile in view topic.
dzyasseron
    Ubuntu Firefox
Post by dzyasseron »
Oh great
thank you
cristian
    Windows XP Firefox
Post by cristian »
Thankyou :beers: :beers: nice mod
