3.1 & 3.2 Extensions DatabaseACP Style
Logged in via: Android device
ACP Style
Extension Name: ACP Style
Author: dmzx and martin
This extension will add a different style to ACP.
Background colour can be changed in ext\dmzx\acpstyle\styles\all\theme\acpstyle.html to whatever you like. :wink:
Purge the cache after enabling the extension.
downloadsystemcat?id=33
  2. Unzip the downloaded release, and change the name of the folder to `acpstyle`.
  4. Copy the `acpstyle` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/acpstyle/composer.json
  6. Look for `ACP Style` under the Disabled Extensions list, and click its `Enable` link.
This topic has 7 replies
