3.1.x Extensions Database 3.1 / 3.2Button roll effect
Button roll effect
Extension Name: Button roll effect
Author: dmzx and martin
Roll effect on big and small buttons on hover or clicked.
Added roll for jumpbox and pagination
Video:
YouTube Video
downloadsystemcat?id=45
  2. Unzip the downloaded release, and change the name of the folder to `buttonroll`.
  4. Copy the `buttonroll` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/buttonroll/composer.json
  6. Look for `Button roll effect` under the Disabled Extensions list, and click its `Enable` link.
Re: Button roll effect
Version update see Update Version 1.0.1 · dmzx/Button-roll-effect@2fa4f60 · GitHub for changes.
