3.2 & 3.3 Extensions Database 3.2 / 3.3Unique Visits Counter
Extension Name: Unique Visits Counter
This extension is based on the visitor’s IP address. The IP address of the new visitor is checked to see if it does not already exist in the table of the extension. If the IP address does not exist, it is registered in the table of the extension and is counted as a new visit.
Visits will be deleted after 24 Hours.
- Code cleanup.
- Updated code.
- Deleted version check ACP and loader js/img.
- Changed language files.
- Updated migration for ip6.
- Updated version check for ssl and fix ACP error for settings page.
- Updated template files to Twig.
- Updated website link in files.
Added ACP module with version check.
Added prune for delete.
Code update.
Code Update
  2. Unzip the downloaded release, and change the name of the folder to `counter`.
  4. Copy the `counter` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/counter/composer.json
  6. Look for `Unique Visits Counter` under the Disabled Extensions list, and click its `Enable` link.
Re: Unique Visits Counter
Version Update see Update Version 1.0.1 · dmzx/Unique-Visits-Counter@3409084 · GitHub for changes.
Taka51
    Windows Vista Firefox
Post by Taka51 »
Hello Dmzx
Here is the French translation of this extension counter unique visits I have I done to my server
Have a nice week end
dmzx-Unique-Visits-Counter-Translate french.zip
WebDvdBdR - Page d’index
Taka51 wrote:Hello Dmzx
Thanks Taka51 :thumbup:
cece74
Post by cece74 »
Language It:
it.zip
Sorry for my English, I'm Italian!
https://forum.scartoff.it
elsa23
Post by elsa23 »
Hi, I have an old board, online for 12 years a go
it is possible ton incrise visits counter, such as, i will not begin from 0 visits when i install ext but from 1 million visits, to have an approximative count close to reality for my 12 years
thanks :buigen:
sorry for my bad english
elsa23 wrote: 10 years ago Hi, I have an old board, online for 12 years a go
thanks :buigen:
No it will count IP's so unless you want to add them.
After enabled...
[phpBB Debug] PHP Notice: in file [ROOT]/phpbb/db/migration/tool/module.php on line 483: Undefined index: module_langname
Then going to Unique Visits Counter settings gave me a white page. Had to disable it.
I get issues with pretty topic ext also.
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Environment.php(403) : eval()'d code on line 23: file_exists(): open_basedir restriction in effect. File(./../theme/prettytopic.css) is not within the allowed path(s)
I wonder if I need a fresh install... :think: using 3.1.10 update. I've been having problems.
Need someone else to check latest Unique Visits Counter release.
There is major bug in 3.1.10 with the migration.
Check it on 3.2 or 3.1.9
Yes smooth install in 3.1.9 looking Great! :thumbup:
Sniper_E wrote: 9 years ago Yes smooth install in 3.1.9 looking Great! :thumbup:
nelflucifer
Post by nelflucifer »
Translation for the Russian Federation
counter_ru_nelflucifer.zip
English Forums
amrco
Post by amrco »
What is the meaning of : Same time will be used for prune visits ?
prune visits, explain this more plz to translate it very well
amrco wrote: 9 years ago What is the meaning of : Same time will be used for prune visits ?
Hi and welcome,
This means when you set the time for visits to example 2 hours the prune will be also 2 hours.
Prune means that the members will me deleted then after 2 hours from the database table automatic.
Hope this explains it a bit more :wink:
