3.1 & 3.2 Extensions DatabaseStatistics on Index
Statistics on Index
Extension Name: Statistics on Index
Author: Stoker extension by dmzx
Statistics on Index gives more statistics on Forum index.
Added Events
Statistics on Index v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `statsonindex`.
  4. Copy the `statsonindex` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/statsonindex/composer.json
  6. Look for `Statistics on Index` under the Disabled Extensions list, and click its `Enable` link.
This topic has 26 replies
Register Logout
