3.2 & 3.3 Extensions Database 3.2 / 3.3Paypal Donation
Paypal Donation
Extension Name: Paypal Donation
Author: Stoker extension by dmzx
A simple Paypal Donation extension
[travis]dmzx/paypaldonation[/travis]
- Drop support for 3.1.
- Twig update.
Update code in listener.
Update code in donation controller.
Compatible with 3.2 (icon).
Added acp_donation language file.
Deleted donation_goal_currency_enable.
Code update
Code update
Code update
Code update utf8_normalize_nfc on currency
Code update
Code update
On index show % after value 3
On donate page show % after value 5
Add yellow bar image
Code update
Add admin log
Top of forum
Bottom of forum
Demo:
If you like it donate :P
  2. Unzip the downloaded release, and change the name of the folder to `donation`.
  4. Copy the `donation` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/donation/composer.json
  6. Look for `Paypal Donation` under the Disabled Extensions list, and click its `Enable` link.
JohnDory
Re: Paypal Donation
Post by JohnDory »
I've just tried installing it and got the following error.
General Error
SQL ERROR [ mysqli ]
Table 'harry_et_forum.phpbb_donation' doesn't exist [1146]
SQL
INSERT INTO phpbb_donation (config_name, config_value) VALUES ('donation_body', ''), ('donation_success', ''), ('donation_cancel', '')
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 855
CALL: trigger_error()
LINE: 194
LINE: 650
LINE: 377
CALL: phpbb\db\driver\driver->sql_multi_insert()
FILE: [ROOT]/ext/dmzx/donation/migrations/donation_schema_1.php
LINE: 43
CALL: phpbb\db\driver\factory->sql_multi_insert()
CALL: dmzx\donation\migrations\donation_schema_1->insert_sample_data()
FILE: [ROOT]/phpbb/db/migrator.php
LINE: 550
CALL: call_user_func_array()
LINE: 496
CALL: phpbb\db\migrator->run_step()
LINE: 322
CALL: phpbb\db\migrator->process_data_step()
LINE: 202
CALL: phpbb\db\migrator->try_apply()
LINE: 185
CALL: phpbb\db\migrator->update_do()
FILE: [ROOT]/phpbb/extension/base.php
LINE: 80
CALL: phpbb\db\migrator->update()
FILE: [ROOT]/phpbb/extension/manager.php
LINE: 187
CALL: phpbb\extension\base->enable_step()
FILE: [ROOT]/includes/acp/acp_extensions.php
LINE: 184
CALL: phpbb\extension\manager->enable_step()
LINE: 674
CALL: acp_extensions->main()
FILE: [ROOT]/adm/index.php
LINE: 81
CALL: p_master->load_active()
Cheers.
Mike.
Peralta
Re: Paypal Donation
Post by Peralta »
Thanks dmzx :buigen:
Tested on my test site and it works great :thumbup:
JohnDory
Re: Paypal Donation
Post by JohnDory »
It must be something wrong with mine as I just tried systeminfo and got
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/systeminfo/event/listener.php on line 44: shell_exec() has been disabled for security reasons
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5133: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3843)
I have quite a few extensions in there, must be a conflict somewhere, time to go through it again I think.
Re: Paypal Donation
Update version Paypaldonation by dmzx
JohnDory
Re: Paypal Donation
Post by JohnDory »
dmzx wrote:Update version Paypaldonation by dmzx
works like a charm :thumbup:
Re: Paypal Donation
dmzx test on mine testboard, works :tumbsyes:
I have also made the Dutch translation for the people who are interested:
Paypal Donation vesrion 0.0.2 - Dutch Translation.zip
Re: Paypal Donation
Jaantje wrote:dmzx test on mine testboard, works :tumbsyes:
Thanks Jaantje
Re: Paypal Donation
New version 0.1.0 see Update version 0.1.0 · dmzx/paypaldonation@5ae59e7 · GitHub for changes :wink:
Re: Paypal Donation
New Version see update version 0.1.1 · dmzx/paypaldonation@1cb8309 · GitHub for changes.
Re: Paypal Donation
New Version see Update version 0.1.2 · dmzx/paypaldonation@6bbeda8 · GitHub for changes.
Re: Paypal Donation
Problem with the install from version 0.1.2.:
Algemene fout
Duplicate entry 'donation_body' for key 'PRIMARY' [1062]
SQL
BACKTRACE
CALL: msg_handler()
LINE: 855
LINE: 194
LINE: 650
LINE: 377
FILE: [ROOT]/ext/dmzx/donation/migrations/donation_sample_data.php
LINE: 49
CALL: dmzx\donation\migrations\donation_sample_data->insert_sample_data()
LINE: 550
LINE: 496
LINE: 322
LINE: 202
LINE: 185
LINE: 80
LINE: 187
LINE: 184
LINE: 674
LINE: 81
Breng de forumbeheerder of sitebeheerder op de hoogte: jacko@jaantje.eu
Re: Paypal Donation
dmzx thanks for your cooperation. It works perfectly again :tumbsyes:
Re: Paypal Donation
Jaantje wrote:dmzx thanks for your cooperation. It works perfectly again :tumbsyes:
:wink:
Re: Paypal Donation
New version available see Update Version 0.1.3 · dmzx/paypaldonation@b3c4e01 · GitHub for changes
