Extensions Database 3.1 / 3.2 ⇒ 3.1 & 3.2 & 3.3 PM Notify & Guest Register bar
3.1.x & 3.2.x
13 given 1
Extension Name: PM Notify & Guest Register bar
Author: Stoker extension by dmzx
This extension will add PM Notify & Guest Register bar.
[travis]dmzx/pmregbar[/travis]
- Twig update.
Validation version
Code update
Code update
  1. Download the latest release and Unzip the downloaded release.
  2. Copy the dmzx/pmregbar folder to /ext/ (if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/pmregbar/composer.json).
  3. Navigate in the ACP to Customise -> Manage extensions
  4. Look for PM Notify & Guest Register bar under the Disabled Extensions list, and click its Enable link.
Peralta
Re: PM Notify & Guest Register bar
Post by Peralta »
Thank you very much dmzx :buigen:
..but are you sure it works in "all" styles :question:
13 given 1
Dmzx, very nice job you have made. Thanx you.
13 given 1
Version 1.0.1 added acp controls
13 given 1
Version 1.0.2 added alternative text field
1 given 1
I had this on 3.0.12 but left out the code for the reg part :lol:
dmzx when I switch on the private messages I get beamed into your extension no PM and no notification . If I use the private messaging beam blanker I 'll get a notification!!
1 given 1
Just incorporated this into my theme :lol: :lol:
martin wrote:I had this on 3.0.12 but left out the code for the reg part :lol:
That is why we have dmzx take care of things around here. :lol:
Jaantje wrote:dmzx when I switch on the private messages I get beamed into your extension no PM and no notification . If I use the private messaging beam blanker I 'll get a notification!!
problem solved , wrong language file :wall:
13 given 1
Please the Dutch translation
nl.zip
1 given 1
Send your self a pm on mine hahaha
1 given 1
If you use the navbar ext then your need to play with the css for the reg/pm bar as shown in the video
video its mp4
css code
* @package PM Notify & Guest Register bar extension.
* @author dmzx (www.dmzx-web.net)
* @copyright (c) 2015 by dmzx (www.dmzx-web.net)
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
#info {
    overflow: visible;
	min-width: 750px;
    width: 100%;
    position: fixed;
    left: 0;
    z-index:200;
    margin-top: 6px;
    font-family: Verdana, Arial, Helvetica, sans-serif;
    font-size: 1.5em;
	font-weight: bold;
#infobar a, #infobar a:link, #infobar a:visited, #infobar a:active {
    display: block;
    float: left;
    width:100%;
    clear: both;
    color: #FFAF34;
    padding: .85em 0 .85em 0;
	text-align: center;
    text-decoration: none;
	background-position: bottom;
	background-repeat:repeat-x;
#infobar a:hover {
    color: #FFAF34;
	background-position: top;
	cursor: pointer;
