Extensions Database 3.1 / 3.2 ⇒ 3.1 & 3.2 phpBB Countdown
3.1.x & 3.2.x
15 given 2
phpBB Countdown
Extension Name: phpBB Countdown
Author: Stoker phpBB3 BBCodes - Forum extension by dmzx
The phpBB Countdown extension display a countdown in your forum header, just below the navbar. It can be configured in ACP. You can enable/disable the countdown and set it to count down or count up. You can also set the date and a text displayed before the countdown and a text that will replace the countdown when finished.
[travis]dmzx/countdown[/travis]
Added admin controller.
Added Changelog file.
Added acp language file.
Updated code.
Code update
Added up/down to lang file and acp module file change and added version in acp.
Xmas and new year edition. Updated
dmzx_countdown_1_0_5.zip
  2. Unzip the downloaded release, and change the name of the folder to `countdown`.
  4. Copy the `countdown` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/countdown/composer.json
  6. Look for `PhpBB Countdown` under the Disabled Extensions list, and click its `Enable` link.
1 given 2
Re: PhpBB Countdown
Tested installs fine but no acp settings go to system tab admin module managment tab click ext countdown module was made but not in the ext tab.
15 given 2
Re: PhpBB Countdown
martin wrote:Tested installs fine but no acp settings go to system tab admin module managment tab click ext countdown module was made but not in the ext tab.
Yes have to look at that, if you add the module manually the ext. will work.
1 given 2
Re: PhpBB Countdown
Bert
Re: PhpBB Countdown
Post by Bert »
Hello from Germany,
not perfect, but maybe it will help further - language_de
Greeting
common.php
<?php
* @package phpBB Extension - PhpBB Countdown
* @copyright (c) 2015 dmzx - https://www.dmzx-web.net
* @Author Stoker - http://www.phpbb3bbcodes.com
* DO NOT CHANGE
if (!defined('IN_PHPBB'))
	exit;
if (empty($lang) || !is_array($lang))
	$lang = array();
// DEVELOPERS PLEASE NOTE
// All language files should use UTF-8 as their encoding and the files must not contain a BOM.
// Placeholders can now contain order information, e.g. instead of
// 'Page %s of %s' you can (and should) write 'Page %1$s of %2$s', this allows
// translators to re-order the output of data while ensuring it remains correct
// You do not need this where single placeholders are used, e.g. 'Message %d' is fine
// equally where a string contains only two placeholders which are used to wrap text
// in a url you again do not need to specify an order e.g., 'Click %sHERE%s' is fine
// Some characters you may want to copy&paste:
	'COUNT_YEARS'				=> 'Jahre',
	'COUNT_MONTHS'			=> 'Monate',
	'COUNT_DAYS'				=> 'Tage',
	'COUNT_HOURS'				=> 'Std',
	'COUNT_MINUTES'			=> 'Min',
	'COUNT_SECONDS'			=> 'Sek',
	'INSTALL_COUNTDOWN'					=> 'Installiere PhpBB Countdown',
	'INSTALL_COUNTDOWN_CONFIRM'			=> 'Bist du bereit, die PhpBB Countdown Extension zu installieren?',
	'COUNTDOWN'							=> 'PhpBB Countdown',
	'COUNTDOWN_EXPLAIN'					=> 'Installiere PhpBB Countdown Datenbankänderungen mit UMIL Auto Verfahren.',
	'UNINSTALL_COUNTDOWN'				        => 'Uninstall PhpBB Countdown',
	'UNINSTALL_COUNTDOWN_CONFIRM'		        => 'Bist du bereit, die PhpBB Ext. Countdown zu deinstallieren? Alle gespeicherten Einstellungen und Daten von dieser Ext. werden entfernt!',
	'UPDATE_COUNTDOWN'					=> 'Update PhpBB Countdown',
	'UPDATE_COUNTDOWN_CONFIRM'			=> 'Bist du bereit, die PhpBB Countdown Ext. zu aktualisieren?',
	'ACP_COUNTDOWN_CONFIG'				=> 'PhpBB Countdown',
	'ACP_COUNTDOWN_CONFIG_EXPLAIN'		        => 'Dies ist die Konfigurationsseite für Countdown Extension by <a href="https://www.dmzx-web.net"><strong>dmzx</strong></a>. Author Stoker.',
	'COUNTDOWN_VERSION'					=> 'Version',
	'COUNTDOWN_DONATE'					=> 'Bitte beachte <a href="http://www.phpbb3bbcodes.com/donate.php"><strong>Donation</strong></a> wenn dir die Extension gefällt',
	'ACP_COUNTDOWN_CONFIG_SET'			=> 'Konfiguration',
	'COUNTDOWN_CONFIG_SAVED'			        => 'PhpBB Countdown Einstellung gespeichert',
	'COUNTDOWN_ENABLE'		                => 'Aktiviere Countdown',
	'COUNTDOWN_ENABLE_EXPLAIN'			=> 'Aktiviere oder Deaktiviere PhpBB Countdown hier',
	'COUNTDOWN_DIRECTION' 			        => 'Countdown Anweisung',
	'COUNTDOWN_DIRECTION_EXPLAIN'		=> 'Der Countdown kann sowohl nach oben und unten zählen. Ja wählen, um nach unten zu zählen',
	'COUNTDOWN_DATE' 					        => 'Countdown Datum',
	'COUNTDOWN_DATE_EXPLAIN'			=> 'Example: 2012/11/30 00:00:00',
	'COUNTDOWN_TEXT' 					=> 'Countdown Text',
	'COUNTDOWN_TEXT_EXPLAIN'			=> 'Der Countdown Text wird direkt vor dem Countdown angezeigt. Sie können HTML nutzen',
	'COUNTDOWN_COMPLETE'	 			=> 'Vollständiger Countdown Text',
	'COUNTDOWN_COMPLETE_EXPLAIN' 		=> 'Dieser Text wird den Countdown ersetzen wenn er abgeschlossen ist. Sie können HTML nutzen',
	'COUNTDOWN_TESTMODE' 				=> 'Aktiviere Testmode',
	'COUNTDOWN_TESTMODE_EXPLAIN'		=> 'Wenn Testmodus aktiviert ist können nur Administratoren den Countdown sehen',
	'COUNTDOWN_YEAR'	 				=> 'Aktiviere Jahre',
	'COUNTDOWN_YEAR_EXPLAIN' 			=> 'Aktiviere diese Funktion um Jahre im Countdown zu anzuzeigen',
	'COUNTDOWN_MONTH'	 			=> 'Aktiviere Monate',
	'COUNTDOWN_MONTH_EXPLAIN' 		=> 'Aktiviere diese Funktion um Monate im Countdown anzuzeigen',
	'COUNTDOWN_OFFSET_ENABLE' 			=> 'Aktiviere die Zeitzone',
	'COUNTDOWN_OFFSET_ENABLE_EXPLAIN' 	=> 'Aktivieren oder Deaktiveren der Zeitzone',
	'COUNTDOWN_OFFSET' 					=> 'Zeitzone Einstellung',
	'COUNTDOWN_OFFSET_EXPLAIN'			=> 'Wenn du eine bestimmte Zeitzone für alle Benutzer verwenden möchtest, kannst du diese hier eingeben.<br />Eine "-6" für Central Standard Time und "4" für Golf Standard Time',
info_acp_countdown.php
<?php
	exit;
	$lang = array();
	'ACP_COUNTDOWN'			=> 'PhpBB Countdown',
	'COUNTDOWN_CONFIG'		=> 'PhpBB Countdown Einstellung',
15 given 2
Re: PhpBB Countdown
Bert wrote:Hello from Germany,
Greeting
Updated :tumbsyes:
15 given 2
Re: PhpBB Countdown
Extension Version: 1.0.2
1 given 2
Re: PhpBB Countdown
Small fix change $(this).html("{COUNTDOWN_COMPLETE}");
leadingZero: true,
to
leadingZero: false,
demo on mine
15 given 2
Re: PhpBB Countdown
martin wrote:Small fix change $(this).html("{COUNTDOWN_COMPLETE}");
leadingZero: true,
to
leadingZero: false,
demo on mine
Indeed hate the leadingZero :wink:
Re: PhpBB Countdown
ext/dmzx/countdown/language/en/common.php
'COUNTDOWN_OFFSET_ENABLE_EXPLAIN' 	=> 'Enable or disable the Ptimezone here',
'COUNTDOWN_OFFSET_ENABLE_EXPLAIN' 	=> 'Enable or disable the timezone here',
The P from Ptimezone is too much :thumbup:
Re: PhpBB Countdown
Se il vous plaît the dutch translation :wink:
nl.zip
15 given 2
Re: PhpBB Countdown
Jaantje wrote:se il vous plaît the dutch translation :wink:
nl.zip
:thumbup: added!
1 given 2
Re: PhpBB Countdown
Css file
.timecount{
	min-height:20px;
Much better.
Allen42
Re: PhpBB Countdown
Post by Allen42 »
This extension works greatly, and set the countdown on my live forums for the new phpBB board version releases and also happy new year (every year)! :thumbup:
atessa_61
Re: PhpBB Countdown
Post by atessa_61 »
The letter "ñ" writes me as "??" in the Spanish language.
