Extensions Database 3.1 / 3.2 ⇒ 3.1 & 3.2 System Info
3.1.x & 3.2.x
15 given 2
System Info
Extension Name: System Info
phpBB extension that will add System Info to your board index.
System, Board version, Server Uptime and Average load.
Demo:
  2. Unzip the downloaded release, and change the name of the folder to `systeminfo`.
  4. Copy the `systeminfo` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/systeminfo/composer.json
  6. Look for `System Info` under the Disabled Extensions list, and click its `Enable` link.
Re: System Info
dmzx thanks again for the lovely extension. :buigen:
1 given 2
Re: System Info
Pls note this will only work on a linux platform if your host has you on windows system then the load will not work your be looking at a blank white page.
15 given 2
Re: System Info
martin wrote:Pls note this will only work on a linux platform if your host has you on windows system then the load will not work your be looking at a blank white page.
linux only :wink:
Re: System Info
I'll try it out when I get back to my computer.
awr
0 given 1
Re: System Info
Post by awr »
Turkish language pack for this extensions.
tr.rar
15 given 2
Re: System Info
awr wrote:Turkish language pack for this extensions.
tr.rar
Added Thanks!
JohnDory
Re: System Info
Post by JohnDory »
Works here but I get the following error
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/systeminfo/event/listener.php on line 44: shell_exec() has been disabled for security reasons
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5133: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3843)
any idea :?:
Cheers.
Mike.
Re: System Info
It shows your System version and Board's phpBB version. Would it be possible to show your PHP version of the server also?
It shows the MySQL version in our ACP and it would be nice for it to show the server's PHP version in there also. Image martin
15 given 2
Re: System Info
Sniper_E wrote:It shows your System version and Board's phpBB version. Would it be possible to show your PHP version of the server also?
event\listener.php
$os              = php_uname('s') . ' ' . php_uname('r');
$php_version = PHP_VERSION;
'BOARD_VERSION'		  => $this->config['version'],
'PHP_VERSION'		  => $php_version,
styles\prosilver\template\event\index_body_stat_blocks_after.html
<p>{L_SYSTEM_NAME} <strong>{PHP_OS}</strong> &bull; {L_BOARD_VERSION}: <strong>{BOARD_VERSION}</strong><br />
<p>{L_SYSTEM_NAME} <strong>{PHP_OS}</strong> &bull; {L_BOARD_VERSION}: <strong>{BOARD_VERSION} </strong> &bull; {L_PHP_VERSION}: <strong>{PHP_VERSION}</strong><br />
language\en\common.php
'BOARD_VERSION'            => 'Board version',
'PHP_VERSION'              => 'PHP version',
Clear the cache :wink:
15 given 2
Re: System Info
JohnDory wrote:works here but I get the following error
any idea :?:
Is shell_exec off on your server?
JohnDory
Re: System Info
Post by JohnDory »
Yes it was, its on now and its now running as it should :thumbup:
cristian
Re: System Info
Post by cristian »
Thankyou man nice code :music: :w00t: :tumbsyes: :tumbsyes: :eusa_dance:
infspirit
Re: System Info
Post by infspirit »
Spanish language pack for this extensions.
15 given 2
Re: System Info
infspirit wrote:Spanish language pack for this extensions.
Thanks added!
