3.1 & 3.2 Extensions Database 3.1 / 3.2MODx commands
MODx commands
Extension Name: MODx commands
phpBB extension that will add MODx commands in a dropbox.
dmzx/Member-time-counter
Add class
Change code
Change code
Change code / White space
Demo:
MODx commands v1.0.4
  2. Unzip the downloaded release, and change the name of the folder to `modxcommands`.
  4. Copy the `modxcommands` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/modxcommands/composer.json
  6. Look for `MODx commands` under the Disabled Extensions list, and click its `Enable` link.
Re: MODx commands
Dmzx, thanx I like to use this
discovery
Re: MODx commands
Post by discovery »
Plop
Language French :
language-Fr.zip
:wave:
Re: MODx commands
discovery wrote:Plop
Language French :
language-Fr.zip
:wave:
Code updated :thumbup:
Sycron
Re: MODx commands
Post by Sycron »
Romanian traslation: ro
Re: MODx commands
Sycron wrote:Romanian traslation: ro
spaceace
Re: MODx commands
Post by spaceace »
How can you add the
bbcode that you have here to this? or does it have to be a separate bbcode? also, what is the code for your
bbcode?
Re: MODx commands
Note this is the code needed to beef up the look of the modx box so your need to work out how to add some of the edits to the ext do not use this code if you have the ext installed
Open prosilver/template/posting_buttons.html
<!-- IF S_BBCODE_FLASH -->
         <input type="button" class="btnbbcode bbcode-flash" accesskey="d" name="addbbcode18" value="Flash" onclick="bbstyle(18)" onmouseover="helpline('d')" onmouseout="helpline('tip')" />
       <select name="addbbcode" onchange="bbfontstyle('[inst]' + this.form.addbbcode.options[this.form.addbbcode.selectedIndex].value, '[/inst]');this.form.addbbcode.selectedIndex = 0;" title="{L_MODX_INST}">
          <option value="0" selected="selected" style="display: none">{L_MODX_CMD}</option>
          <option value="[open][color=#232F43][b][size=120]Open:[/size][/b][/color] [/open]">{L_MODX_OPEN}</option>
          <option value="{L_BBCODE_AFTER}">{L_MODX_AFTER}</option>
          <option value="{L_BBCODE_BEFORE}">{L_MODX_BEFORE}</option>
          <option value="{L_BBCODE_REPLACE}">{L_MODX_REPLACE}</option>
          <option value="{L_BBCODE_DELETE}">{L_MODX_DELETE}</option>
          <option value="{L_BBCODE_INAFTER}">{L_MODX_INAFTER}</option>
          <option value="{L_BBCODE_INBEFORE}">{L_MODX_INBEFORE}</option>
          <option value="{L_BBCODE_INREPLACE}">{L_MODX_INREPLACE}</option>
          <option value="{L_BBCODE_INDELETE}">{L_MODX_INDELETE}</option>
       </select>
Open language/en/posting.php
'MORE_SMILIES'            => 'View more smilies',
'MODX_INST'               => 'Post Edits for  MODx Install Directions',
       'MODX_CMD'               => 'MODx Instructions',
       'MODX_OPEN'            => 'Open',
       'MODX_AFTER'            => 'Find and Add after',
       'MODX_BEFORE'            => 'Find and Add before',
       'MODX_REPLACE'            => 'Find and Replace with',
       'MODX_DELETE'            => 'Find and Delete',
       'MODX_INAFTER'            => 'Inline Find Add after',
       'MODX_INBEFORE'            => 'Inline Find Add before',
       'MODX_INREPLACE'         => 'Inline Find Replace with',
       'MODX_INDELETE'            => 'Inline Find and Delete',
       'BBCODE_OPEN'         => '[color=#232F43][b][size=120]Open:[/size][/b][/color] ',
       'BBCODE_AFTER'         => '[color=#232F43][b][size=120]Find[/size][/b][/color]
    Tip: [size=85]This may be a partial find and not the whole line.[/size][code]
Add after
Tip: Add the following line(s) on a new blank line after the preceding line(s) of find.',
'BBCODE_BEFORE' => 'Find
Tip: This may be a partial find and not the whole line. Add before
Tip: Add the following line(s) on a new blank line before the preceding line(s) of find.',
'BBCODE_REPLACE' => 'Find
Tip: This may be a partial find and not the whole line. Replace with
Tip: Replace the preceding line(s) to find with the following line(s).',
'BBCODE_DELETE' => 'Find
Tip: This may be a partial find and not the whole line. Delete
Tip: Remove the preceding line(s) to find.',
'BBCODE_INAFTER' => 'Find
Tip: This may be a partial find and not the whole line. [inline]In-Line Find
Tip: This is a partial match of a line for in-line operations. In-Line Add after
Tip: Add the following code(s) in-line after the preceding in-line code(s) to find.[/inline]',
'BBCODE_INBEFORE' => 'Find
Tip: This is a partial match of a line for in-line operations. In-Line Add before
Tip: Add the following code(s) in-line before the preceding in-line code(s) to find.[/inline]',
'BBCODE_INREPLACE' => 'Find
Tip: This is a partial match of a line for in-line operations. In-Line Replace with
Tip: Replace the preceding in-line code(s) to find with the following code(s).[/inline]',
'BBCODE_INDELETE' => 'Find
Tip: This is a partial match of a line for in-line operations. In-Line Delete
Tip: Remove the preceding in-line code(s) to find.[/inline]',[/code]
Now create a couple (a few) BBCodes
Go to ACP / Posting / Click: Add a new BBCode
BBCode usage:
[inst]{TEXT}[/inst]
HTML replacement:
<div class="inst-wrapper"><div class="inst-content">{TEXT}</div></div>
Click: Submit
BBCode usage:
[inline]{TEXT}[/inline]
HTML replacement:
<div class="inst-inline">{TEXT}</div>
Click: Submit
In these instructions I added an optional BBCode for a Open BBCode
BBCode usage:
[open]{TEXT}[/open]
HTML replacement:
<div class="inst-open">{TEXT}</div>
Click: Submit
Then add some classes
Open prosilver/theme/colours.css
Find
li.notification-reported strong, li.notification-disapproved strong {
	color: #D31141;
Add after
.inst-open {
	background: #FFFFFF;
	padding: 4px 10px 10px;
	margin-bottom: -27px;
	width: 50%;
	border: solid 1px #999999;
	border-top-left-radius: 7px;
	border-top-right-radius: 7px;
	-webkit-border-top-left-radius: 7px;
	-webkit-border-top-right-radius: 7px;
	-moz-border-top-left-radius: 7px;
	-moz-border-top-right-radius: 7px;
	z-index: 10000;
.inst-wrapper {
	padding: 1px;
	border-radius: 8px;
	-webkit-border-radius: 8px;
	-moz-border-radius: 8px;
	margin-bottom: 1px;
.inst-content {
	background: #D6E6F6;
	padding: 6px 10px;
	border: solid 1px #C6DAEE;
	border-radius: 7px;
	-webkit-border-radius: 7px;
	-moz-border-radius: 7px;
.inst-inline {
	background: #DDEEFF;
	padding: 6px 10px;
	border: solid 1px #6699CC;
You can see above that I added an extra .inst-open class for the optional [ open] [/ open] BBCode.
Refresh Templates and Theme
Credit to Sniper_E
spaceace
Re: MODx commands
Post by spaceace »
This would hard code it into the style. i'm looking to add it to the extension in the first post here.
Re: MODx commands
Yup i should have posted that but it's not hard to work out the needed edits to be added to the ext :wink:
spaceace
Re: MODx commands
Post by spaceace »
martin wrote:Yup i should have posted that but it's not hard to work out the needed edits to be added to the ext :wink:
not hard at all but if others see it, and add it to the style and also have the extension installed... could cause some funny stuff to happen :lol:
Re: MODx commands
Edited my post with a large notice lol if you would be so kind as to remove the quote from your post it may not confuse some.
spaceace
Re: MODx commands
Post by spaceace »
Now that it's added to the ext... i want it in the dropdown but without using the install and code bbcodes. just to have all the modx stuff in one dropdown. here's what i'm getting now when i click the open bbcode in the dropdown
[install][open][color=#232F43][b][size=120]Open:[/size][/b][/color] [/open] [code]
[/install][/code]
spaceace
Re: MODx commands
Post by spaceace »
A little research shows that i can't get this how i wanted due to the "onchange" in the template element. onchange can not be canceled :wink:
Re: MODx commands
Fresh install of 3.1.4 this part of the code is broke
<select name="addbbcode21" onchange="bbfontstyle('[install]' + this.form.addbbcode21.options[this.form.addbbcode21.selectedIndex].value + ' [code]', '
[/install]');this.form.addbbcode21.selectedIndex = 0;" title="{L_MODX_CMD}">
<option value="{L_BBCODE21_FIND}">{L_MODX_FIND}</option>
<option value="{L_BBCODE21_AFTER}">{L_MODX_ADD_AFTER}</option>
<option value="{L_BBCODE21_BEFORE}">{L_MODX_ADD_BEFORE}</option>
<option value="{L_BBCODE21_REPLACE}">{L_MODX_REPLACE_WITH}</option>
<option value="{L_BBCODE21_DELETE}">{L_MODX_DELETE}</option>
<option value="{L_BBCODE21_INFIND}">{L_MODX_IN_LINE_FIND}</option>
<option value="{L_BBCODE21_INAFTER}">{L_MODX_IN_LINE_ADD_AFTER}</option>
<option value="{L_BBCODE21_INBEFORE}">{L_MODX_IN_LINE_ADD_BEFORE}</option>
<option value="{L_BBCODE21_INREPLACE}">{L_MODX_IN_LINE_REPLACE_WITH}</option>
</select>[/code]
the bbcode side is fine.
