Extensions Database 3.2 / 3.3 / 4.0 ⇒ 4.0.x BBCode Migrate
3.2 & 3.3 & 4.0
19 given 2
BBCode Migrate
Extension Name: BBCode Migrate
ACP tool: converts posts from one BBCode to another, board-wide. Pick source/destination BBCode and map placeholders using definitions pulled straight from phpbb_bbcodes - no free-text tag names or hand-written regex.
- The conversion is no longer fixed to `[​download]` and `[​dlbutton]`: pick any source and destination BBCode from the list of BBCodes of the board.
- Map the placeholders of the destination BBCode to the source placeholders, either as-is or by extracting a numeric id from a URL (`?id=123`).
- The mapping page is the dry run: it shows how many posts match and previews the first 10 before anything is written.
- A source tag that does not match the expected structure is left untouched and flagged in the preview.
- A button to configure a different conversion after finishing one.
- New migration for the active mapping setting.
  2. Unzip the downloaded release, and change the name of the folder to `bbcodemigrate`.
  4. Copy the `bbcodemigrate` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/bbcodemigrate/composer.json
  6. Look for `BBCode Migrate` under the Disabled Extensions list, and click its `Enable` link.
