3.1 & 3.2 Extensions DatabaseTopic Author
Logged in via: Android device
Extension Name: Topic Author
phpBB extension that will add Topic Author to viewtopic.
Added admin_controller.
Updated listener.
Update code.
Changed language files.
Added text colour field by Mickroz
Add ACP module
Topic Author v1.0.4
  2. Unzip the downloaded release, and change the name of the folder to `topicauthor`.
  4. Copy the `topicauthor` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/topicauthor/composer.json
  6. Look for `Topic Author` under the Disabled Extensions list, and click its `Enable` link.
This topic has 72 replies
