Here are five common mistakes I've seen admins make when testing extensions, and how a proper test environment solves them:
- Mistake 1: Testing on your live board during off-peak hours.
The problem: Even during quiet times, unexpected errors can impact users, break functionality, or even corrupt data. You're still gambling with your community's experience and data integrity.
The fix: Always test on a separate, isolated development environment. This can be a subdomain, a local server, or even a virtual machine. This way, any breakage only affects your test copy, not your actual users. - Mistake 2: Not replicating your live board's environment accurately.
The problem: You test an extension, it works perfectly, but when you move it to live, it crashes. This often happens because the PHP version, database version, server configuration, or even other installed extensions are different between your test and live environments.
The fix: Make your test board as close a clone of your live board as possible. Use the same phpBB version, the same database, and ideally, the same server environment. This includes having a copy of your live database and files. This ensures that if it works on test, it's highly likely to work on live. - Mistake 3: Only testing the installation and immediate functionality.
The problem: An extension installs fine, and its main feature works. But what about edge cases? Does it conflict with other extensions? Does it handle user permissions correctly? Is there a performance hit under load? For example, if you're installing mChat with a bunch of add-ons like GIF Picker or Reactions, you need to see how they all play together over time.
The fix: Conduct thorough testing. Create different user accounts (admin, moderator, registered user, guest) and test all aspects of the extension. Check logs (like the phpBB error log) for hidden issues. If the extension integrates with points, like Ultimate Points, ensure points are awarded correctly. Simulate various user actions. - Mistake 4: Not having a rollback plan.
The problem: You've installed an extension, and it's broken something. Without a backup or a clear path to revert, you're scrambling to fix it while your forum is down or buggy.
The fix: Before any significant change on your live board (after successful testing), always perform a full backup of your database and files. On your test board, practice the installation and uninstallation process for any new extension. This way, if something goes wrong on live, you know exactly how to revert to a working state quickly. - Mistake 5: Not testing updates for existing extensions.
The problem: It's not just new installations; updates to extensions like Download System or Deskflow can also introduce breaking changes or conflicts, especially if you're running many extensions.
The fix: Treat extension updates with the same caution as new installations. Apply updates to your test board first, check for compatibility with your existing setup, and ensure all features still work as expected before updating your live board.
For those of you running test boards, what's one unexpected benefit you've found, or a tip you'd share with other admins setting one up?
