Here’s a practical checklist to help you batten down the hatches against those pesky spammers:
- Review your phpBB registration settings regularly.
- Go to ACP → General → User registration settings.
- Consider enabling Visual confirmation on registration (CAPTCHA). While not foolproof, it's a basic first line of defense.
- For new boards or boards experiencing heavy spam, temporarily set New member post limit to 0 or 1. This means new users need admin approval for their first posts, giving you a chance to catch spam before it goes live.
- The Account activation setting is crucial. User activation (email confirmation) is a must. Admin activation is even stronger for boards with persistent spam, though it requires more manual work.
- Leverage the dmzx Notify Admin on Registration extension.
- This extension, found under ACP → Extensions → Notify Admin on Registration, sends an email notification to selected administrators every time a new user registers. It's fantastic for keeping an eye on new sign-ups in real-time and quickly spotting suspicious usernames or email addresses.
- Utilize the dmzx User Check extension for quick investigations.
- When you do spot a suspicious account, dmzx User Check is your best friend. Install it via ACP → Customise → Manage extensions. Then, when viewing a user's profile, you'll see options to quickly check their IP address against various blacklists, view their registration details, and even see if they've registered other accounts from the same IP. This saves immense time in identifying and banning spam bots.
- Implement a Question & Answer (Q&A) CAPTCHA.
- Beyond the standard visual CAPTCHA, phpBB allows you to create custom Q&A challenges. Go to ACP → General → Spambot countermeasures → Q&A.
- Create simple, unique questions that require human intelligence, not just pattern recognition. Avoid questions easily answered by searching Google. For example, "What is 2 + 2?" is too easy. "What's the last word in 'phpBB is great'" is better. Change these questions periodically.
- Monitor your server logs for unusual activity.
- While not directly a phpBB setting, keeping an eye on your web server access logs can reveal patterns of bot activity, such as rapid-fire registration attempts from specific IP ranges. Tools like dmzx NginxBotShield can automate blocking known malicious bots at the server level, preventing them from even reaching your phpBB installation.
- Consider the dmzx WebAuthn Passkey & Biometric Login extension.
- For a more advanced approach to user verification, WebAuthn allows users to log in with passkeys or biometrics. While primarily for security and convenience, the underlying technology makes it significantly harder for bots to create accounts, as it requires a physical device interaction.
