3.2 & 3.3 Extensions Database 3.2 / 3.3Search extension
Search extension
Extension Name: Extension Search
Author: ivo
Special thanks to: -
Extension Search adds a fast and convenient search field to the phpBB ACP extension management page.
It allows administrators to instantly filter extensions by their display name or package name while typing.
The extension automatically adapts its appearance to the currently active ACP style, including both light and dark styles.
Features:
  • Instant extension search in ACP.
  • Search by extension display name.
  • Search by package name, for example ivo/extensionsearch.
  • Works with enabled, disabled and not installed extensions.
  • Automatically hides empty extension groups while searching.
  • Displays the number of matching extensions.
  • Displays a message when no extensions are found.
  • Press / to quickly focus the search field.
  • Press Esc to clear the current search.
  • Automatically adapts to the active ACP style.
  • Compatible with dark and light ACP styles.
  • No database modifications required.
extensionsearch-1.0.1.zip
  2. Unzip the downloaded release and change the name of the folder to extensionsearch.
  3. In the ext directory of your phpBB board, create a new directory named ivo if it does not already exist.
  4. Copy the extensionsearch folder to /ext/ivo/. If done correctly, you will have the extension files at:
    (your forum root)/ext/ivo/extensionsearch/composer.json
  5. Navigate in the ACP to Customise -> Manage extensions.
  6. Look for Extension Search under the Disabled Extensions list and click its Enable link.
