Extensions Database 3.2 / 3.3 ⇒ 3.3.x Download Beacon Add on
3.2.x & 3.3.x
13 given 1
Extension Name: Download Beacon
A [dlbutton] BBCode for forum posts that always shows the current title, version, and download count of a Download System file - the button stays accurate even in old posts, without ever needing to edit them.
Add on for https://www.dmzx-web.net/viewtopic.php?p=5401#p5401
See here below
  2. Unzip the downloaded release, and change the name of the folder to `downloadbeacon`.
  4. Copy the `downloadbeacon` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/downloadbeacon/composer.json
  6. Look for `Download Beacon` under the Disabled Extensions list, and click its `Enable` link.
13 given 1
Re: Download Beacon Add on
