3.3.x Extensions Database 3.2 / 3.3ChatBot
ChatBot
Extension Name: ChatBot
A lightweight forum assistant integrated into phpBB that helps users search the board, look up members, and access common forum actions — right from a small chat widget.
What it does (features)
  • Full-text conversational search across topics and posts; returns top threads with short snippets and links.
  • Quick member lookup using user:username or u:username — shows profile summary and recent posts.
  • “Compose PM” helper: lookup a user and open UCP compose window with a single click.
  • “Show latest posts” shortcut that opens the board’s newest posts search.
  • Popular suggestions and recent-search chips in the widget to speed repeated queries.
  • Inline highlighting of search terms in returned thread links (uses dmzx_q query param).
  • Feedback controls on results (👍 / 👎) sent to the server for review.
Admin features:
  • ACP page to view/search chatbot logs, mark entries reviewed and purge old logs.
  • Config options in ACP: enable/disable the entire chatbot, toggle popular suggestions, set suggestion/history limits.
  • Admin logging for settings changes, purges, and review actions.
How to use it (patterns & examples)
Basic usage is very natural — type what you want and press Enter.
  • Search the forum:
    Example: Chatbot Topic
    → returns matching threads with snippets and links.
  • Lookup a user:
    Use user:username or u:username (case-insensitive).
    Example: user:janedoe or u:janedoe
    → returns profile card, joined date, post count and recent posts with links.
  • Compose PM helper:
    Click the “Compose PM” suggestion, enter recipient username, and the widget gives a link to the UCP compose screen.
Quick commands (widget suggestions):
  • FAQ — opens the board FAQ.
    Show latest posts — opens newest posts search (search.php?search_id=newposts).
    Click any suggestion chip to run that query.
Smart suggestions (automatic patterns the bot recognizes):
  • ucp, user control panel — suggests link to your UCP.
    pm, private message, compose message — suggests compose PM link.
    avatar, change avatar — link to UCP avatar settings.
    password, account, profile — link to profile/account settings.
    These are matched with simple regex-like patterns, so you can type natural phrases containing those words.
Multi-line input:
  • Use Shift+Enter to add a newline in the input; Enter sends the query.
Recent searches & popular suggestions:
  • Recent searches are saved locally (browser localStorage) and capped by the ACP-configured limit.
    Popular suggestions are fetched from server logs and limited by configuration.
Highlighting thread content:
  • When you open a returned thread link, the extension can add ?dmzx_q=your+query (or the dmzx_q param is included) so the page highlights matched terms automatically.
    If a thread link includes a post anchor like #p123, the highlighting will focus inside that post.
Admin / ACP controls
  • Global enable/disable for the chatbot (turns the widget off entirely).
    Enable/disable popular suggestions.
    Set limits:
    Number of popular suggestions to show (default 3).
    Number of recent searches to keep (default 3).
    ACP log viewer: inspect searches, feedback, review state, mark reviewed and purge logs.
ChatBot v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `chatbot`.
  4. Copy the `chatbot` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/chatbot/composer.json
  6. Look for `ChatBot` under the Disabled Extensions list, and click its `Enable` link.
