Extension official releasesphpbb [3.3.x] Extensions Database Releases • Database Optimize & Repair Tool
Extension name: Database Optimize & Repair Tool
Author: MattF
Extension description: This extension allows you to check, optimize and repair phpBB's database tables from a phpMyAdmin-like interface in the Administration Control Panel. Select specific tables (such as only those having overhead) or all of them at once.
OPTIMIZE will defragment your database and can offer improved database performance.
REPAIR should only be used if you believe your database has crashed or corrupt tables.
CHECK will report on the status of tables.
Features:
  • Optimize, Repair or Check tables directly from the ACP or the Command Line Interface
  • Select individual or all tables independently
  • Displays table size and table overhead values
  • Option to safely disable board during the optimize/repair process
  • Actions are logged to the Admin log
  • Nice javascript interactions
  • Multiple languages are supported. View the pre-installed localizations.
Minimum Requirements:
  • v1.2.x requires phpBB 3.2.x or phpBB 3.3.x
  • v1.1.x requires phpBB 3.1.x or phpBB 3.2.x
  • MySQL 4.0.1 or higher
  • MyISAM, InnoDB and Archive table types only
This extension is a port of my MOD from phpBB 3.0.x.
Extension version: 1.2.1
Tested on phpBB version: 3.3.15
Download file: vse_dbtool_1.2.1.zip
File size: 58.16 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?p=16081903#p16081903
