3.3.x Extensions Database 3.2 / 3.3Config Save [Add On]
Extension Name: Config Save [Add On]
Config Save [Add On] needs Admin Config Page, Export or import extension configuration, tables and metadata.
Config Save v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `configsave`.
  4. Copy the `configsave` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/configsave/composer.json
  6. Look for `Config Save` under the Disabled Extensions list, and click its `Enable` link.
