3.2 & 3.3 Extensions Database 3.2 / 3.3Topic Pins
Topic Pins
Extension Name: Topic Pins
Pin posts to your forum.
  2. Unzip the downloaded release, and change the name of the folder to `topicpins`.
  4. Copy the `topicpins` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/topicpins/composer.json
  6. Look for `Topic Pins` under the Disabled Extensions list, and click its `Enable` link.
