Extension official releasesphpbb [3.3.x] Extensions Database Releases • Bump Topic Override
    Android Android
Extension name: Bump Topic Override
Author: deiuwhite
Extension description: This extension modifies the default phpBB bump behavior by removing the restriction that prevents users from bumping a topic more than once without a new reply.
By default, phpBB checks whether a topic has already been bumped and blocks further bumps until a new reply is made. This extension removes that condition, allowing users to bump their topics solely based on the time interval set in:
ACP > General > Board Configuration > Post Settings > Bump interval.
Original phpBB check in includes/functions_content.php:
Code:
// Check permission and make sure the last post was not already bumpedif (!$auth->acl_get('f_bump', $forum_id) || $topic_bumped){ return false;}This extension removes the "|| $topic_bumped" condition - setting it to False - so users can bump topics repeatedly as long as the bump interval has passed, without needing an additional reply.
Extension version: 1.0.0
Tested on phpBB version: 3.3.15
Download file: bump-topic-override.zip
File size: 8.79 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?p=16068733#p16068733
