Extension official releasesphpbb [3.3.x] Extensions Database Releases • Auto Database Backup
Extension name: Auto Database Backup
Author: RMcGirr83
Extension description: This extension will automatically backup your database using the phpBB 3.1 Cron.
Main features:
  • enable/disable auto database backup,
  • Auto db backup frequency,
  • database optimization,
  • the quantity of stored backups,
  • the backup time,
  • the backup file type - gzip, bzip2 or text.
All backups are stored in folder 'store'. You can restore and download them using phpBB backup functions (Maintaince -> Backup Module -> Restore). You don't need to use ftp access to download them.
Attention
When you set 'Stored backups' for ex. to 10 and you already have more than 10 backups, all the oldest backups will be deleted on the next auto backup time and there will be only 10 stored backups.
This extension is a port of the Auto Backup from phpBB 3.0.x.
Extension version: 2.0.0
Tested on phpBB version: 3.3.10
Download file: autodbbackup.zip
File size: 16.94 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?p=15975046#p15975046
