Extension official releasesphpbb [3.3.x] Extensions Database Releases • Filter by country
    unknown Mozilla
Extension name: Filter by country
Author: MarkDHamill
Extension description: This extension filters traffic by country. An administrator can either allow traffic from selected countries only, or not allow any traffic from selected countries. It helps reduce unwanted traffic to a forum and makes the forum’s content entirely inaccessible to blocked countries.
The extension uses the free MaxMind GeoLite2 country database. The database examines the IP address of the user and determines the country of origin.
You must acquire a license key to download the MaxMind database. I recommend you do this before installing the extension. You must register on the MaxMind site, but you don’t have to pay for a licensed version of this database. In fact, it works only with the free GeoLite2 country database. You will get a set of one-time credentials that you should retain somewhere safe. You will also need to enter the license key on the extension’s settings page. Without a valid license key, the database cannot be downloaded by the extension.
Some boards attract a lot of spam, often times malicious robots from countries like Ukraine, Russia or Belarus trying to create spam accounts and spam posts. This extension may be part of this solution. Other boards really don’t want traffic from outside the country because their focus is strictly national, or applies only to a set of given countries. This extension can prohibit the rest.
There are other ways to block traffic by country. For example, CloudFlare has a paid service that can do this. These solutions have the advantage of keeping this traffic from ever hitting your site, which reduces server resources used. This extension though might be preferable, as it has features that allow registered users to login even if their country is blocked, if this feature is enabled.
Extension version: 1.0.19
Tested on phpBB version: 3.3.2
Download file: filterbycountry_1.0.19.zip
File size: 664.66 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2589886&p=15699576#p15699576
