Extension official releasesphpbb [3.2.x] Extensions Database Releases • Reduce Search Index
Extension name: Reduce Search Index
Author: Dark❶
Extension description: This Extension Lets Admin to control phpBB Native Fulltext Search Index .
Status Badge for Reduce Search Index [RSI] on phpBB v3.3.x :
Requirements: phpBB 3.2.9 & 3.3.0 (or current 3.{2,3}.x dev) or above.
Features:
  • Option to Enable/Disable this extension.
  • Option to set the Time from which Search Index is Kept, Also Time before which Search Index is Deleted.
  • Option to set Interval to Update the above Time when Cron is run.
  • Option to Topic + Lock / Topic Only / Post Only / Disable for each Forum.
    • Topic + Lock : Search Index from the Forum for the Topic is Deleted and Locked as per the above Time.
    • Topic Only : Search Index from the Forum for the Topic is Deleted as per the above Time.
    • Post Only : Search Index from the Forum for the Post is Deleted as per the above Time.
  • Option to Enable/Disable the Cron task to Reduce Search Index.
  • Option to set Interval for Cron task.
  • Option to set the Last Run Time for Cron task.
  • Option to Run the Cron task.
  • Display Reduced Notice on Search Page.
Notes:
  • phpBB Native Fulltext fulltext_native : This is Fully Supported.
  • MySQL Fulltext fulltext_mysql : This can not be Supported because it's fully DataBase side implementation & management.
  • PostgreSQL Fulltext fulltext_postgres : This can not be Supported because it's fully DataBase side implementation & management.
  • Sphinx Fulltext fulltext_sphinx : This can not be Supported because it's fully Sphinx class side implementation & management , which is outside the scope of phpBB.
    Ref: viewtopic.php?p=15452286#p15452286
Links:
Instructions : Installation / Updation / Uninstallation
GitHub Repository : reducesearchindex
GitHub Repository Language Packs : reducesearchindex> lang-pack
For more Details Go Here : Reduce Search Index [RSI]
Credit where credit's due:
Date & Time Picker : Any+Time by Andrew M. Andrews III at ama3.com/anytime,
which can be found at dark1/reducesearchindex/styles/all/template/DateTimePicker.
EnJoY
Best Regards.
Extension version: 1.0.1
Tested on phpBB version: 3.2.10
Download file: phpBB-ext-dark1-reducesearchindex-v1.0.1.zip
File size: 62.85 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2566406&p=15582621#p15582621
