Extension official releases ⇒ phpbb [3.3.x] Extensions Database Releases • Quick Login
Official release
Extension name: Quick Login
Author: PayBas
Extension description: Extension for phpBB 3.1 that adds a simple quick login popup lightbox using JavaScript.
Features:
  • Just a simple lightbox popup for quick login actions.
  • Changes the behaviour of the normal login button in the header.
  • Only activates on pages where there is no normal login form (not when trying to access the UCP for example).
Languages: No language files included/necessary
  • Download and unzip the current release.
  • Copy the paybas/quicklogin folder to /ext/paybas/quicklogin.
  • Navigate in the ACP to Customise -> Manage extensions.
  • Look for "Quick Login" under the Disabled Extensions list, and click the "Enable" link.
Development: https://github.com/Sajaki/QuickLogin
Extension version: 1.1.3
Download file: QuickLogin-1.1.3.zip
File size: 133.22 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2564921&p=15573841#p15573841
