Author: dmzx & martin
Checks if files posted are missing from the files folder of your board.
- Code cleanup.
- Add autosort for files.
- Download-link
- Missing files v1.0.1
- Unzip the downloaded release, and change the name of the folder to `missingfiles`.
- Copy the `missingfiles` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/missingfiles/composer.json - Navigate in the ACP to `Customise -> Manage extensions`
- Look for `Missing Files` under the Disabled Extensions list, and click its `Enable` link.
