Extension official releasesphpbb [3.3.x] Extensions Database Releases • Empty Post Subjects
Extension name: Empty Post Subjects
Author: ___Martin
Extension description: Links
Extension development repository: https://github.com/Mar-tin-G/EmptyPostSubjects
Extension Description: Empties the 'Subject' when (quick) replying to a topic. Modifies the text of the Last Post link on the board index or when viewing a forum to handle empty post subjects. Also modifies the search result titles to handle empty post subjects.
Extension Version: 1.1.1
Requirements: phpBB 3.2, phpBB 3.3
Features:
Empties the Post Subject when (quick) replying to a topic. Two settings are added in the ACP:
  • Empties the Subject field in post editor when replying to a topic.
  • Empties the Subject field in the quick reply editor when viewing a topic.
Modifies the text of the Last Post link on the board index or when viewing a forum to handle empty post subjects, because in this case phpBB by default displays no link. Possible settings in ACP:
  • The Last Post link displays the subject of the last post (default, this conforms to the phpBB default),
  • it displays the title of the topic containing the last post, or
  • it displays the post subject if it is not empty and the topic title otherwise.
Note: the following option must be enabled to display Last Post links: ACP > Board Configuration > Board Features > Display subject of last added post on forum list.
Also modifies the search result titles (when displaying search results as posts) to handle empty post subjects. Possible settings in ACP:
  • The search result titles display the subject of the post found by the search (default, this conforms to the phpBB default),
  • they display the title of the topic containing the found post, or
  • they display the post subject if it is not empty and the topic title otherwise.
Extension version: 1.1.1
Download file: martin_emptypostsubjects_1.1.1.zip
File size: 16.38 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2557116&p=15531201#p15531201
