3.2 & 3.3 Extensions Database 3.2 / 3.3Pay for download
Pay for download
Extension Name: Pay for download
Pay for download, this will only work with VIP donation extension viewtopic.php?p=3003#p3003.
With the Donation Extension (version 1.3.2) add Credits when members are donating.
With these credits you can use this extension to set download links, when member who has credits can download, if no credits no more downloads :wink:
This extension will use a coded bbcode so members cannot see the url until they buy it.
If purchased the Download they will have access to ii al the time.
Permissions are in so check them for groups you want to set.
- Code update for $link_no_arrow.
- Code update for UCP when switch off in ACP.
- Added code when donation credits if off no link can be downloaded.
- Use CSS instead of images.
- Several code updates.
- Changed code for enable errors.
- Updated acp_payfordownload_body.html
  2. Unzip the downloaded release, and change the name of the folder to `payfordownload`.
  4. Copy the `payfordownload` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/payfordownload/composer.json
  6. Look for `Pay for download` under the Disabled Extensions list, and click its `Enable` link.
Re: Pay for download
Make em pay for it lol thats a demo in it's self.
umi
Post by umi »
Hi @dmzx, thanks for this ext.
I tested it but link image doesn´t show in topic. Don´t know if I do something wrong...
Regards :beers:
umi wrote: 12 Jun 2020, 18:54 Hi @dmzx, thanks for this ext.
Regards :beers:
check if iframe is on.
umi
Post by umi »
dmzx wrote: 12 Jun 2020, 18:57
Regards :beers:
Could you let me know where can I check that?
Wait, I see your language is not en copy the en folder in payfordownload/styles/all/theme and rename to your language like es
and clear cache. :wink:
umi
Post by umi »
dmzx wrote: 12 Jun 2020, 19:08 wait, I see your language is not en copy the en folder in payfordownload/styles/all/theme and rename to your language like es
Fixed, thanks master!!
https://i.gyazo.com/09c860c8b2d43453e37 ... 85933c.png
:beers: :beers: :beers:
vince
    Mac OS X iPhone
Post by vince »
This is a awsome mod +1
vince
    Mac OS X iPhone
Post by vince »
As a guest they see this
is this sapose to happen thanks
Hamidouki-dz
Post by Hamidouki-dz »
i still have phpbb version 3.2.7
is it functional with this version?
Suggestion:
I find that the style of the button is not pleasant but it will be great if you change it to a prosilver style.
francesca
Post by francesca »
Hi. excellent extension .how we did to put the file to download? thank you
You can ftp the zip or file to a new folder on your server or you can add an upload button as i have.
francesca
Post by francesca »
Sorry for the double post you can detail me to add the upload button. Thanks
francesca
Post by francesca »
Hi can you help me. thanks for making an upload button
Hamidouki-dz
francesca wrote: 22 Jun 2020, 01:32 hi can you help me. thanks for making an upload button
Info removed by martin 100% wrong.
