Extension official releases ⇒ phpbb [3.3.x] Extensions Database Releases • Amazon Affiliate
Official release
Extension name: Amazon Affiliate
Author: HiFiKabin
Extension description: Adds the ability to add your own Amazon Affiliate code the following Amazon or Amzn TLD links posted on your forum. You only need to enter one Affiliate Code per TLD, the extension automatically adds it to both amazon and amzn. Any existing Affiliate Code is stripped first. Javascript needs to be enabled on the users browser for the Affiliate Code to be added.
co.uk, .com, .fr, .de, .ca, .co.jp, .it, .cn, .es, .in, .com.au, .com.mx
Language:
  • en
  • Additional languages: ar, es, fr, nl here
Supported Styles:
  • all
Based on: Affililink v0.21 by Dean Barrow
Demo: Installation:
  • Download the latest release and unzip it.
  • Upload the folder hifikabin to root/ext/ and enable it in the ACP
Support:
The contact us link at the bottom of this Forum or phpBB Forum
Note:
  • The code is added to the link when it is hovered over or clicked, not to the actual posted link
Known Conflicts:
  • s9e/mediaembed users must read this
  • Amazon BBCode
Translators Note:
  • If the amazon TLD's in your region are different to those in this Extension, when you translate language/xx/common.php change the TLD values in lines 55-67 and all settings will change to reflect this, otherwise DO NOT TRANSLATE THESE LANGUAGE STRINGS.
    eg. Change
    'AMAZONAFFILIATE_COUK' => '.co.uk',
    to
    'AMAZONAFFILIATE_COUK' => '.be',
Extension version: 1.1.0
Download file: amazonaffiliate_1_1_0.zip
File size: 16.86 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2555681&p=15522491#p15522491
