Extensions Database 3.2 / 3.3 ⇒ 3.3.x Watermark
3.2.x & 3.3.x
15 given 2
Watermark
Extension Name: Watermark
Watermark automatically images by upload.
Fixed: on phpBB 4.0+, the attachment thumbnail could still come out rotated or upside down even after the 1.0.6 fix below. phpBB core generates the thumbnail from the original upload before this extension gets any chance to touch it, so the thumbnail needed its own, separate fix.
Fixed: photos uploaded from a mobile phone could come out rotated or upside down once watermarked, even though they displayed correctly before watermarking was enabled. GD (used to apply the watermark) ignores a JPEG's EXIF Orientation tag on decode and never writes it back out on encode, so the tag that told the browser how to rotate the image for display was silently lost while the pixels themselves stayed exactly as the camera sensor captured them. The image is now physically rotated/flipped to match its EXIF orientation before the watermark is applied, on both phpBB 3.3.x and 4.0+.
Fixed: no watermark was applied to uploaded images on phpBB 4.0.x, even though ACP settings saved correctly. phpBB 4.0 now triggers core.modify_uploaded_file before the upload reaches its new storage abstraction, and no longer exposes any filesystem path to event listeners at that point, so the 3.3.x-era approach could never find the file. On phpBB 4.0+, watermarking now happens by decorating the storage.attachment service and applying the watermark right before the file bytes are persisted (see di/extension.php and storage/attachment_decorator.php). Behavior on phpBB 3.3.x is unchanged.
Extended supported phpBB range to include 4.0.x.
- Added forum exclude in ACP.
- Added warning if GD is active in ACP.
- Added support for webp images.
- Added code for check mimetype.
- Added orientation of watermark.
- Added position of watermark.
- Added transparency level for watermark.
  2. Unzip the downloaded release, and change the name of the folder to `watermark`.
  4. Copy the `watermark` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/watermark/composer.json
  6. Look for `Watermark` under the Disabled Extensions list, and click its `Enable` link.
The Good
Re: Watermark
Post by The Good »
Plz no chance to have this for 3.2 phpbb ???
I already requested this ext in phpbb.. I really need it !!
https://www.phpbb.com/community/viewtop ... &t=2549071
thanks
1 given 2
Re: Watermark
The Good wrote: 05 Jun 2020, 18:46 plz no chance to have this for 3.2 phpbb ???
thanks
Untested but try this.
Removed its 3.3 only
TrekRed
Re: Watermark
Post by TrekRed »
Works only in attachments or on external resources too?
1 given 2
Re: Watermark
Attachments only.
TrekRed
Re: Watermark
Post by TrekRed »
Is there anything similar to external resources?
Peralta
Re: Watermark
Post by Peralta »
martin wrote: 05 Jun 2020, 18:50
thanks
watermark_v100.zip
:wtf:
La migración “\dmzx\watermark\migrations\install_watermark” no se ha realizado, falta la migración “\phpbb\db\migration\data\v330\v330”.
	public static function depends_on()
		return [
			'\phpbb\db\migration\data\v330\v330'
martin could you modify it to avoid the error?
1 given 2
Re: Watermark
Thought I did that must have uploaded the wrong set yes I will redo them.
1 given 2
Re: Watermark
Ok new files in other post above but you should note this is 3.3 only and i dont have 3.2 to test on.
Peralta
Re: Watermark
Post by Peralta »
:sad: ...It doesn't work, when I try to access the configuration of the extension this error is triggered:
phpBB encontró un error al construir el contenedor debido a una extensión instalada. Por esta razón, todas las extensiones se han desactivado temporalmente. Por favor, intente purgar el caché del foro. Todas las extensiones serán automáticamente habilitadas de nuevo una vez que se resuelva el error del contenedor. Si este error continúa, por favor visite phpBB.com para soporte.
Excepción: The definition for "_defaults" has no class. If you intend to inject this service dynamically at runtime, please mark it as synthetic=true. If this is an abstract definition solely used by child definitions, please add abstract=true, otherwise specify a class to get rid of this error.
#0 /srv/disk1/2868406/***/vendor/symfony/dependency-injection/Compiler/Compiler.php(102): Symfony\Component\DependencyInjection\Compiler\CheckDefinitionValidityPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#1 /srv/disk1/2868406/***/vendor/symfony/dependency-injection/ContainerBuilder.php(587): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#2 /srv/disk1/2868406/***/phpbb/di/container_builder.php(198): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#3 /srv/disk1/2868406/***/common.php(115): phpbb\di\container_builder->get_container()
#4 /srv/disk1/2868406/***/adm/index.php(23): require('/srv/disk1/2868...')
#5 {main}
1 given 2
Re: Watermark
Nope 3.3 only then.
15 given 2
Re: Watermark
For 3.2 some work needs to be done.
service.yml
ext.php
migration file.
1 given 2
Re: Watermark
:wall: services i missed that one.
The Good
Re: Watermark
Post by The Good »
dmzx wrote: 05 Jun 2020, 20:08 for 3.2 some work needs to be done.
service.yml
ext.php
migration file.
thanks guys !! we can wait :thumbup:
The Good
Re: Watermark
Post by The Good »
I think to add also the name of the author will take too much work time !!
