3.3.x Extensions Database 3.2 / 3.3Singapore slinger
Singapore slinger
I have been blasted by bots if you want to call them that but they have almost took me offline so knocked up a little ext to block Singapore (Now the whole of china).
Note who is where may still show them online but there not there off to visit the url you set.
martin_singapore_1_0_3.zip
Updated the code as i found away around it.
1.0.3 works on 3.3 and 3.3.1
This version is for 3.2 only it has no acp settings.
martin_singapore_1_0_1.zip
umi
Re: Singapore slinger
Post by umi »
Tested on phpbb 3.3.0 with some issues:
Doesn´t work if phpbb sitemaker ext is enabled:
Cannot autowire service "martin.singapore.listener": argument "$template" of method "martin\singapore\event\main_listener::__construct()" references interface "phpbb\template\template" but no such service exists. You should maybe alias this interface to one of these existing services: "template", "blitze.sitemaker.template".
    unknown Chrome
I and a few others have tested on phpbb 3.3 with no issues.
If you have a issue and it seems a few and they all relate to site maker then there is your problem.
umi
Post by umi »
martin wrote: 29 May 2020, 17:50 I and a few others have tested on phpbb 3.3 with no issues.
Just report issues as information...
Haha this looks like previous version of martin's bot :D
No nothing like it.
The Good
Post by The Good »
Possible to have this one for 3.2 ???
adding vpn and proxy !!!!!!!!!
No and no.
it blocks a user by there browser lang not ip so vpn/proxy dont even come into it when a user installs a browser the user lang (example france) will be installed as your location is france this you cant alter so if you block france lang your block all of france.
First post updated to v 1.0.3
Maclobster
Post by Maclobster »
1.0.3
Shows some errors in html checker for me
“A man searching for the Lost Paradise, can seem a fool to those who never sought the other world.”
-JM
Are you using the correct checker fot html5 ? https://validator.w3.org/nu/ note the "nu" on the end.
Here is mine https://validator.w3.org/nu/?doc=https: ... -phpbb.com
Here is dmzx https://validator.w3.org/nu/?doc=https% ... zx-web.net
Using just w3.org will show errors as its old and out of date https://validator.w3.org/
Maclobster
martin wrote: 14 Oct 2020, 10:51 Are you using the correct checker fot html5 ? https://validator.w3.org/nu/ note the "nu" on the end.
all links showing same result for me
Singashit passes validation.
I should point out just as an error shows in an ext does not mean that the problem is in the ext! an out of place <div> or <p> in any file on the server can do some funny stuff when it comes to html5 valid.
the links above i posted all come back as html5 valid so the issue is in another file on your server.
Maclobster
martin wrote: 14 Oct 2020, 21:26 Singashit passes validation.
Screenshot from 2020-10-14 20-27-44.pngScreenshot from 2020-10-14 20-27-25.pngScreenshot from 2020-10-14 20-29-02.png
thank you martin, i will look in to it :tumbsyes:
Maclobster
Ok problem is fixxed but..
Going to
- cssmagic
