Extension official releasesphpbb [3.2.x] Extensions Database Releases • phpBB Studio - Spotify OAuth2 light
Extension name: phpBB Studio - Spotify OAuth2 light
Author: phpbbstudio.com
Extension description: Installation
Copy the extension to phpBB/ext/phpbbstudio/spl
Go to "ACP" > "Customise" > "Extensions" and enable the "phpBB Studio - Spotify OAuth2 light" extension.
Application settings:
https://developer.spotify.com/dashboard/applications -> (Create a client ID)
Copy and save the Client ID and Client Secret to use in the ACP / Client communication / Authentication page.
OAuth2 Redirects:
Two links is what you need to use in the Redirect URIs for the application to work.
http://www.example.com/board/ucp.php?mo ... io_spotify
http://www.example.com/board/ucp.php?i= ... io_spotify
Replace http://www.example.com/board with your Board's URL ;-D
Extension version: 1.0.2
Tested on phpBB version: 3.2.8
Download file: phpbbstudio_SPOTIFY_LIGHT_102.zip
File size: 203.48 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2541496&p=15432481#p15432481
