3.3.x Extensions Database 3.2 / 3.3Profile Admin Information
Extension Name: Profile Admin Information
Profile Admin Information, information required for fast support. Admins or Moderator can only see this information on profile page of member.
Profile Admin Information v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `profileadmininfo`.
  4. Copy the `profileadmininfo` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/profileadmininfo/composer.json
  6. Look for `Profile Admin Information` under the Disabled Extensions list, and click its `Enable` link.
awr
Re: Profile Admin Information
Post by awr »
tr.zip
DANYQC
Post by DANYQC »
For some x reason this extension crash my site "i have the latest version of phpbb 3.5" when i update my profil in user control panel... :wall:
Profile Admin Information_1.0.0-Slovenian.zip
DANYQC wrote: 29 Nov 2021, 07:14 for some x reason this extension crash my site "i have the latest version of phpbb 3.5" when i update my profil in user control panel... :wall:
Works fine on my site no issues.
Tested on 3.3.7 and works.
DANYQC
Post by DANYQC »
I update to 3.7 and now its working,thanks friend!! ;-)
