Extension official releasesphpbb [3.2.x] Extensions Database Releases • Image Alternate Text
Extension name: Image Alternate Text
Author: AbaddonOrmuz
Extension description: Allows you to set alternate text to image tags.
BBCode input
CODE:
ImageHTML output
CODE:
Features:
  • It doesn't require additional configuration
  • It has support for the Markdown extension
  • It support Unicode text, including emojis
  • The engine sanitizes the text so no unsafe text is used
Requirements:
  • PHP 5.6 or greater
  • phpBB 3.2 or greater
Extension version: 1.0.0
Tested on phpBB version: 3.2.7
Download file: alfredoramos_imagealt_1.0.0.zip
File size: 9.03 KiB
Read more
