Extensions Database 3.2 / 3.3 ⇒ 3.2 & 3.3 Delete Inactive Users
3.2.x & 3.3.x
13 given 1
Extension Name: Delete Inactive Users
Delete inactive users by cron, can set post count to a value and you can exclude multiple groups.
Separate period for never-activated registrations (default 7 days), independent of the period for activated accounts.
New option "Also delete never-activated registrations": deletes accounts that were never activated (ACP → Users → Inactive users, reason "Newly registered account") once their registration date is older than the selected period. Off by default. Accounts deactivated by an administrator or awaiting re-activation are never touched.
One codebase for phpBB 3.3.x and 4.0.x again: uses messenger.method.email on 4.0 and the legacy messenger on 3.3.
Clearer ACP explanations; email language falls back to the board default.
Fix cron crash "Impossible to set header Sender" when an email to an inactive user fails: the messenger is re-initialised per user and a failed send no longer aborts the run.
Users are deleted before the admin log entry is written; failed emails are logged separately.
Email language falls back to the board default language.
Code update for phpBB 4.0.0-a1
- Code cleanup.
- Update composer.json
- Code update
- Added admin log for deleted users.
- Added option for email message to deleted users.
Added option to show message after register user.
  2. Unzip the downloaded release, and change the name of the folder to `deleteinactiveusers`.
  4. Copy the `deleteinactiveusers` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/deleteinactiveusers/composer.json
  6. Look for `Delete Inactive Users` under the Disabled Extensions list, and click its `Enable` link.
thecaretaker thanked this post
Re: Delete Inactive Users
Thanks dmzx, I will use for sure. :)
1 Question?
Select period:
Set period of inactivity by users. Registration date and last activity date.
Does this mean even if you have 1 or more posts and you do not come to the board or login for a year no matter what group you get booted?
13 given 1
clight77 wrote: 24 Apr 2019, 13:19 1 Question?
Select period:
If you set this period the extension checks if the member is active in this period or registered. The Post count is the important value to set, I have it only on 0 so members that are not active will be deleted after that period.
Maybe?
Or am I overthinking this.. lol
13 given 1
clight77 wrote: 24 Apr 2019, 13:59 Maybe?
No, the extension does look at this time, otherwise the post set is also direct for new members that have lately registered to your board.
OK thanks :)
1 given 2
So if users are with 0 post their account will be deleted? :roll:
13 given 1
ivailo95 wrote: 24 Apr 2019, 14:26 so if users are with 0 post their account will be deleted? :roll:
Yes after the period of time is past.
So if a member just register and dont post anything he will be deleted after x period.
Painkiller88
    unknown Mozilla
Post by Painkiller88 »
Just to be sure:
This just happens to User with 0 posts? So for example a User registers, creates 1 Post and after that he is inactive for lets say 1 Year, his account won't be deleted because he already created 1 post.
Or does it mean 1 post in the last 6 months, 1 year etc..?
Sry i am normally not that dumb :D
13 given 1
Painkiller88 wrote: 24 Apr 2019, 14:32 This just happens to User with 0 posts? So for example a User registers, creates 1 Post and after that he is inactive for lets say 1 Year, his account won't be deleted because he already created 1 post.
Yes when you set 0 above is correct.
Great ext! Thank you
1 given 2
I suggest to create log for this ex i mean when user is delete this action can be show in ACP
1 given 1
Vip members get the logged version :rolling: freebie users get the junk.
1 given 2
So, i set 3 post count, 1 hour and 7 days (today,15.05.2019year)
now who is now made 3 post his account will be deleted after 7 day (on 22.05.2019year) need to be deleted on this date
