Extensions Database 3.2 / 3.3 ⇒ 3.2.xLight-Dark Extension
3.2.x & 3.3.x
9 given 1
Extension Name: Light-Dark Extension
Author: dmzx & martin
By the idea from martins's Dark / Light style changer.
This extension will change brightness for now, It can be adjusted to whatever style you need in file:
ext\dmzx\lightdark\styles\all\theme\lightdark.css
ACP control included.
[travis]dmzx/Light-Dark-Extension[/travis]
  2. Unzip the downloaded release, and change the name of the folder to `lightdark`.
  4. Copy the `lightdark` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/lightdark/composer.json
  6. Look for `Light-Dark Extension` under the Disabled Extensions list, and click its `Enable` link.
NAPWR
Re: Light-Dark Extension
Post by NAPWR »
Great work DM & MM :tumbsyes:
My name is Dave I, and all things are out there, and we are in here :mml:
1 given 2
Good work :thumbup: :mml:
1 given 1
I got a nice update for this il post it when i get out of hospital.
raykai
Post by raykai »
Not working in phpBB v3.3.0
1 given 1
raykai wrote: 29 May 2020, 09:57 Not working in phpBB v3.3.0
The hint is this part here in the tittle 3.2
try this one for 3.3
dmzx_lightdark_1_0_0.zip
raykai
Post by raykai »
martin wrote: 29 May 2020, 10:19
it's working now for phpBB v3.3.0.
raykai
Post by raykai »
This extension has a conflict with Reading progressbar viewtopic.php?f=66&t=4126 The bar stops working if dark mode is turned on on your account.
Checked on 3.3.7 and it works. Thanks
Light-Dark Extension_1.0.0-Slovenian.zip
ramboagent
    Windows 10 Edge
Post by ramboagent »
Bei der version 3.3.11 wird nix angezeigt kommt auch keine Fehlermeldung
I was working on an extension last year that was based off of martin's dark style css.
I asked dm if he could help me make the index button change to dark style with just a click without having to go to ucp.
I gave up on that and just created a dark style. Now I found this ext and here it is. Just what I was asking help for.
I just installed this on my test site but it's acting weird.
In db when lightdark_status is set to '0' I see the dark style. In db when lightdark_status is set to '1' I see the light style.
That does not look like it is working correctly.
I even changed the codes in the navbar_header_user_profile_prepend.html to this:
<i id="favIcon" class="icon fa fa-{% if S_LIGHTDARK_DARK %}sun{% else %}moon{% endif %}-o fa-fw" title="{% if S_LIGHTDARK_DARK %}{{ lang('LIGHTDARK_LIGHT_STYLE') }}{% else %}{{ lang('LIGHTDARK_DARK_STYLE') }}{% endif %}"></i>
These codes were backwards in the index. When in dark style the moon showed with the 'Dark style' title.
Switching the codes around took care of that issue.
I'll have to look into this deeper to see why it's functioning the way it does. Anyone else see what I see with your install?
Sniper_E wrote: 20 Dec 2023, 20:39In db when lightdark_status is set to '0' I see the dark style. In db when lightdark_status is set to '1' I see the light style.
That does not look like it's working correctly. It's backwards.
I found the problem. In dm's event/main_listener.php
'S_LIGHTDARK_DARK' 	=> $this->user->data['lightdark_status'] ? false : true,
It needed to be written as...
'S_LIGHTDARK_DARK' 	=> $this->user->data['lightdark_status'] ? true : false,
