3.1 & 3.2 Extensions Database 3.1 / 3.2Fixed Navbars
4 given 0
Fixed Navbars
Extension Name: Fixed Navbars
This extension will make your header and footer navbars fixed to your board and can be controlled in UCP for members.
[travis]dmzx/Fixed-Navbars[/travis]
  2. Unzip the downloaded release, and change the name of the folder to `fixednavbars`.
  4. Copy the `fixednavbars` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/fixednavbars/composer.json
  6. Look for `Fixed Navbars` under the Disabled Extensions list, and click its `Enable` link.
Wil
Re: Fixed Navbars
Post by Wil »
This installed
Only the footer is fixed
Deze geïnstalleerd
Alleen de footer is gefixeerd
Regards,
Wil
Sorry my English is not my basic language
Wil
Re: Fixed Navbars
Post by Wil »
The footer covers my links.
So the extension can not be on my forum.
Forget the previous post
De footer bedekt mijn links.
De extensie kan dus niet op mijn forum.
Vergeet de vorige post
Painkiller88
    Mac OS X Firefox
Re: Fixed Navbars
Post by Painkiller88 »
Seems not to work properly on 3.2.5, only the footer bar is fixed, header isn't :(
Re: Fixed Navbars
Ucp settings.
It has to work as its working here and on mine and many other sites.
Painkiller88
    Mac OS X Firefox
Re: Fixed Navbars
My settings are exactly the same, but i am using the style Carbon.
I also disabled fixed header setting and reenabled it in UCP, still not working for me.
Re: Fixed Navbars
There's your problem custom theme 99% of ext's are made for prosilver this ext comes with a all folder so it should show unless your theme is messed up.
Re: Fixed Navbars
Yes the Carbon style is a custom style and the header and navbar are rewritten. Your header navbar is carbon-topper in that style.
You will need a carbon directory in the extension's styles folder. Your css would need different classes to work.
Painkiller88
    Mac OS X Firefox
Re: Fixed Navbars
Ok thanks for your reply, than i know where i have to work on.
wads24
Re: Fixed Navbars
Post by wads24 »
Is there a fix for the mobile responsive fixed footer for phpbb-3.3.1? Right side menu popup is not showing correctly.
4 given 0
Re: Fixed Navbars
wads24 wrote: 06 Sep 2020, 07:00 Is there a fix for the mobile responsive fixed footer for phpbb-3.3.1? Right side menu popup is not showing correctly.
Please post image to check what you mean?
wads24
Re: Fixed Navbars
Post by wads24 »
dmzx wrote: 16 Sep 2020, 11:08
Nevermind.... I found fix for this issue here https://github.com/phpbb/phpbb/pull/6033/files
Thanks @dmzx
Re: Fixed Navbars
Thats not a fix it's in 3.3.1 by default.
i0x
Re: Fixed Navbars
Post by i0x »
Navbars not show correctly on phpbb 3.3.2 on 500px, 412px and 320px screens, i'll upload fixed css here today
i0x
Re: Fixed Navbars
Post by i0x »
Not showing correctly on range of screens from 690px to 200px
