Extensions Database 3.2 / 3.3 ⇒ 3.2 & 3.3 Image Upload
3.2.x & 3.3.x
15 given 2
Image Upload
Extension Name: Image Upload
Author: dmzx & martin
This extension will add an upload system for images to your forum.
This will allow you to host your own images from your server rather than use a 3rd party.
Allowed extensions can be set in ACP.
Set permission for groups, default only admin group can upload images.
Before you update backup you files folder in the extension folder!
- Fixed switch's for mchat pop up or open tab.
- Fixed options mchat button.
- Moved js.
- Added code for popup and extra options in ACP.
- Code update UCP delete images.
- Code update to path_helper.
- Style redo for mobile by martin.
- Changed pagination on index/ucp/posting pages.
- Style update CSS and html.
- Added multiple upload section.
- Added permission for multiupload.
- Added sweetalert2 js for images.
- limit php.ini value in ACP.
- Various code changes.
- Added ACP switches for global on/off index and posting images.
- Added permission to view tab in UCP.
- Changed layout of title and delete/insert images.
- Added pagination for images.
- Various code updates.
- Fix deleting images on lower php version.
- Changed HSIMG to URL-IMG link.
- Added ACP options for link display.
- Deleted code for 3.1 uploading files.
Best settings for lightbox users.
- Rename "files" dir to "img-files" thanks to g0lang.
- Code update for 3.3.x
- Changed code for ACP for deleting images.
Note: Keep in mind if you update the old images still will be in files folder, so url to those images will point to files folder. just leave the files folder so they wont break. I did empty the db image_upload table so no broken images are shown in UCP and ACP. And it will start again when uploading files. This is only when you have already installed this extension
- Drop support 3.1.x
- Added allowed extensions for images in ACP.
- Moved functions to core/functions.
- Changed code for allowed extensions in controller.
- Changed code for Collapsible Categories 2.
Changed code for deleting image
Added scroll bar in UCP if large amount of images are uploaded.
Code update.
Added option to delete images from UCP. (See permissions default only Admin group can delete images)
Added button in posting topic for IMG direct in post.
Changed code for close conflict with boardannounce .
Changed html to twig.
Code update.
Added new copy function
Added code for members to see own uploaded images. On posting page and Index page.
Added UPC setting for uploaded images on index to show for member.
Added direct insert to mchat on index. (if mchat is installed)
Added multiple delete in ACP
Added sorting
Note: You need to disable and delete data for this version. If you already use images make a backup from Files folder and place them back after update.
Added md5 for file names.
Added ACP option to see / delete images.
Added a button on the posting page that open a nice popup.
Added size and width/height to show on upload.
Code update.
  2. Unzip the downloaded release, and change the name of the folder to `imageupload`.
  4. Copy the `imageupload` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/imageupload/composer.json
  6. Look for `Image Upload` under the Disabled Extensions list, and click its `Enable` link.
Hippie459MN
Re: Image Upload
Post by Hippie459MN »
NICE! Going to check this out. Maybe be better than my goofy solution I got going on. lol
"I went outside once. The graphics sucked but the game play was ok."
Puchahawa
Re: Image Upload
Post by Puchahawa »
Hey DM, I've been playing with this a bit and decided to move the link to Posting_editor_message_after so it would be right there where folks would be making their post. My question is how can I make it so the link opens in a new tab. I figure if someone is posting and chooses to add an image that they wouldn't want to loose what they are posting to do so. Opening the upload in a separate tab would allow them to deal with the image and keep their post info as is. :smile:
15 given 2
Re: Image Upload
Yes can be target blank.
Will post it when home or martin will do :wink:
[ Post made via Samsung Galaxy S4 ] Image
15 given 2
Re: Image Upload
Puchahawa wrote: 31 Jan 2017, 04:34 Hey DM, I've been playing with this a bit and decided to move the link to Posting_editor_message_after so it would be right there where folks would be making their post. My question is how can I make it so the link opens in a new tab. I figure if someone is posting and chooses to add an image that they wouldn't want to loose what they are posting to do so. Opening the upload in a separate tab would allow them to deal with the image and keep their post info as is. :smile:
Add target="_blank" to the link to open in new window.
Puchahawa
Re: Image Upload
Post by Puchahawa »
Would that be in the Posting_editor_message_after event file? If so does it matter where I put that?
1 given 2
Re: Image Upload
Yes it does wait a few mins and il remove my mchat image uploader and give you the code you want new window or popup ? see my mchat for popup and navbar for new tab.
Puchahawa
Re: Image Upload
Post by Puchahawa »
Thanks Martin! :tumbsyes: Thinking new tab.
1 given 2
Re: Image Upload
Try here first before i have to change code pls just hit the image upload http://www.martins.homelinux.net/forum/ ... e=post&f=5
Puchahawa
Re: Image Upload
Post by Puchahawa »
Pop up looks like it would work well also for keeping the person on the post page while adding an image.
1 given 2
Re: Image Upload
Cool beans i now have it built into the ext :tumbsyes: just need to test it
1 given 2
Re: Image Upload
Puchahawa
Re: Image Upload
Post by Puchahawa »
Testing the version you just uploaded with the pop up window on a 3.2.0 board Martin. The submit button for the image doesn't seem to do anything. :yikes: :eyes2:
pop up comes up ok. Choose the file ok. click the submit button and nada. file is only 125kb so that shouldn't be an issue.
1 given 2
Re: Image Upload
Purge the boards cache it's working as if on the index page only difference is the code is also in an event.
Puchahawa
Re: Image Upload
Post by Puchahawa »
:wtf: :wtf: No go. Tried clearing board cache and chromes cache nothing. disabled ext and deleted data then re-enabled and same thing. The button is there but it acts like it's "not hooked up". click the button and nothing. running 3.2.0 board. and php 55.12 on wampserver.
