3.2.x Extensions DatabaseTop Stats 3.2.x
Top Stats 3.2.x
Extension Name: Top Stats
The Top Stats extension displays some cool stats on your forum index.
- Changed code for Collapsible Categories 2.
- Twig update.
Code update
Top Stats v1.0.2
  2. Unzip the downloaded release, and change the name of the folder to `topstats`.
  4. Copy the `topstats` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/topstats/composer.json
  6. Look for `Top Stats` under the Disabled Extensions list, and click its `Enable` link.
This topic has 107 replies
