Extensions Database 3.1 / 3.2 ⇒ 3.1 & 3.2 & 3.3 Countdown Header
3.1.x & 3.2.x
13 given 1
Countdown Header
Extension Name: Countdown Header
Countdown in header, configurable in ACP
- Code update for conflict with phpBB Countdown extension.
- Code cleanup.
- Twig Update.
- URL update
- Added admin_controller
- Added acp language file
- Updated listener
- Updated acp_countdownheader_config.html
- Updated overall_header_breadcrumbs_after.html
Code update
  2. Unzip the downloaded release, and change the name of the folder to `countdownheader`.
  4. Copy the `countdownheader` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/countdownheader/composer.json
  6. Look for `Countdown Header` under the Disabled Extensions list, and click its `Enable` link.
proavia
    Windows 7 Internet Explorer
Re: Countdown Header
Post by proavia »
I like the idea of having the countdown in the header! :thumbup:
BTW - 25 days until I can go get what??? :whistl:
13 given 1
proavia wrote: 14 Dec 2016, 00:51 BTW - 25 days until I can go get what???
Some nice announcement :wink:
proavia
Post by proavia »
I'll be waiting!!! :eyes2: :eusa_dance:
moffacostanzo
Post by moffacostanzo »
with ext member time counter doesnn't function on my board
13 given 1
moffacostanzo wrote: 14 Dec 2016, 15:12 hi
Yes have seen this also will check if combination can be done.
moffacostanzo
Ok
and olso statistics on index
1 given 1
24 days and this ext is dead :rolling:
Siava
Post by Siava »
dmzx wrote: 14 Dec 2016, 00:52Some nice announcement :wink:
phpbb 3.2 release? :D
1 given 1
It works on 3.2
13 given 1
martin wrote: 15 Dec 2016, 19:45It works on 3.2
Think he means what is the announcement :lol:
caju
Post by caju »
This extension in phpbb.com website still display the countdown when on mobile, but in my installation and in dmzx-web.net website don't.
Is this a configurable feature?
Kind regards,
13 given 1
caju wrote: 15 Dec 2016, 20:26 This extension in phpbb.com website still display the countdown when on mobile, but in my installation and in dmzx-web.net website don't.
Kind regards,
No on mobile this version will be hiding the counter, on phpbb.com they have different custom header so thats why it shows there.
caju
Post by caju »
Thanks, dmzx :tumbsyes:
Puchahawa
Post by Puchahawa »
Am I the only one wondering why the number of days seems to be off by 6 or so days for new years? :yikes: :whistl:
