3.1 & 3.2 Extensions Database 3.1 / 3.2Basic Stats
Basic Stats
Extension Name: Basic Stats
Author: oxpus - dmzx made it compatible for 3.2
Basic Stats on your forum see link in footer. (founder only!)
basicstats_v102.zip
  2. Unzip the downloaded release, and change the name of the folder to `basicstats`.
  3. In the `ext` directory of your phpBB board, create a new directory named `oxpus` (if it does not already exist).
  4. Copy the `basicstats` folder to `/ext/oxpus/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/oxpus/ /composer.json
  6. Look for `Basic Stats` under the Disabled Extensions list, and click its `Enable` link.
zardos
Re: Basic Stats
Post by zardos »
Very nice :thumbup:
lopoto
Re: Basic Stats
Post by lopoto »
THX :eyes2:
Mickroz
Re: Basic Stats
Post by Mickroz »
Q: Whats a hash and a root password?
A: hash gets you high, root password gives you god powers, combine the 2 and you are invincible.
nelflucifer
Re: Basic Stats
Post by nelflucifer »
Good extension! I like it. Translation for the Russian Federation.
basicstat_rus_nelflucifer.zip
English Forums
novw
Re: Basic Stats
Post by novw »
What means "(founder only!)" ?
Re: Basic Stats
novw wrote: 01 Mar 2017, 21:56 what means "(founder only!)" ?
The board founder only.
novw
Re: Basic Stats
Post by novw »
dmzx wrote: 01 Mar 2017, 22:02
Usually the "admin" :) :) Can the page be set to public access? ?
Re: Basic Stats
Basic Stat does not work together with " Statistics on Index " .... tested
only for informationen
Basix stat works now fine....good job :thumbup:
novw
Re: Basic Stats
Post by novw »
novw wrote: 02 Mar 2017, 21:57 Can the page be set to public access? ?
Please? I have been looking at php\event\main_listener.php _and_ controller\main.php, both hold the "USER_FOUNDER". I can see how to remove the
		if ($this->user->data['user_type'] <> USER_FOUNDER)
			throw new http_exception(403, 'NOT_AUTHORISED');
from one, but the other
		if ($this->user->data['user_type'] == USER_FOUNDER)
is abacadabra to me...
Re: Basic Stats
novw wrote: 08 Mar 2017, 20:25 Please? I have been looking at php\event\main_listener.php _and_ controller\main.php, both hold the "USER_FOUNDER". I can see how to remove the
ext\oxpus\basicstats\event\main_listener.php
<?php
* @package phpBB Extension - Basic Stats
* @copyright (c) 2015 OXPUS - www.oxpus.net
* @copyright (c) 2016 dmzx - https://www.dmzx-web.net
namespace oxpus\basicstats\event;
use Symfony\Component\DependencyInjection\Container;
use Symfony\Component\EventDispatcher\EventSubscriberInterface;
class main_listener implements EventSubscriberInterface
	/* @var string phpEx */
	protected $php_ext;
	/* @var \phpbb\controller\helper */
	protected $helper;
	/* @var \phpbb\template\template */
	protected $template;
	/* @var \phpbb\user */
	protected $user;
	/** @var \phpbb\files\factory */
	protected $files_factory;
	* Constructor
	* @param string									$php_ext
	* @param \phpbb\controller\helper				$helper
	* @param \phpbb\template\template				$template
	* @param \phpbb\user							$user
	* @param \phpbb\files\factory					$files_factory
	public function __construct(
		$php_ext,
		\phpbb\controller\helper $helper,
		\phpbb\template\template $template,
		\phpbb\user $user,
		\phpbb\files\factory $files_factory = null)
		$this->php_ext 			= $php_ext;
		$this->helper 			= $helper;
		$this->template 		= $template;
		$this->user 			= $user;
		$this->files_factory 	= $files_factory;
	static public function getSubscribedEvents()
		return array(
			'core.page_header'	=> 'add_link_to_stats',
	public function add_link_to_stats($event)
		$ext_main_link = $this->helper->route('basicstats_controller');
		$this->user->add_lang_ext('oxpus/basicstats', 'common');
			'U_BASIC_STATS' => $ext_main_link,
			'PHPBB_IS_32'	=> ($this->files_factory !== null) ? true : false,
ext\oxpus\basicstats\controller\main.php
<?php
namespace oxpus\basicstats\controller;
use phpbb\exception\http_exception;
class main
	/* @var \phpbb\db\driver\driver_interface */
	protected $db;
	protected $helper;
	/* @var \phpbb\request\request_interface */
	protected $request;
	protected $user;
	/* @var \phpbb\config\config */
	protected $config;
	* Constructor
	* @param \phpbb\db\driver\driver_interfacer		$db
	* @param \phpbb\request\request_interface 		$request
	* @param \phpbb\config\config					$config
		\phpbb\db\driver\driver_interface $db,
		\phpbb\request\request_interface $request,
		\phpbb\user $user,
		\phpbb\config\config $config)
		$this->db 						= $db;
		$this->request					= $request;
		$this->config 					= $config;
		$this->u_action					= $this->helper->route('basicstats_controller');
	public function handle($view = '')
		// Define the ext path
		$mode		= $this->request->variable('mode', 'm');
		$s_month	= $this->request->variable('s_month', '');
		$s_year		= trim($this->request->variable('s_year', ''));
		switch ($mode)
			case 'd':
				$current_time		= getdate(time()); //calculate the time here which will be used henceforth to prevent any mismatch if date changes at the tick of midnight!!!
				$board_starttime	= getdate($this->config['board_startdate']);
				$start_time = $end_time = $counted_days = 0;
				if (!$s_month)
					$s_month = date('n-Y', $current_time[0]);
				$s_month = explode('-', $s_month, 2); //[0] => month, [1] => year
				if ($s_month[0] == $current_time['mon'] && $s_month[1] == $current_time['year']) //if its the current month
					//check if this is the first month of the board
					if ($board_starttime['mon'] == $current_time['mon'] && $board_starttime['year'] == $current_time['year'])
						$start_time = $board_starttime[0];
					else
						$start_time = mktime(0, 0, 0, $current_time['mon'], 1, $current_time['year']);
					$end_time = $current_time[0];
				else //some different month
					//check if the month is the board startdate month, if so only start days from the board start day
					if ($s_month[0] == $board_starttime['mon'] && $s_month[1] == $board_starttime['year'])
					else
						$start_time = mktime(0, 0, 0, $s_month[0], 1, $s_month[1]);
					$end_time = mktime(0, 0, 0, $s_month[0] + 1, 1, $s_month[1]);
				$start_time	= getdate($start_time);
				$end_time	= getdate($end_time);
				$totals = $max = array('topics' => 0, 'posts' => 0, 'user_reg' => 0);
				$daily_data = array();
				$first_day = $start_time['mday'];
				//$last_day is tricky, i do this this way
				$last_day = date('j', $end_time[0] - 1);
				$counted_days = $last_day - $first_day + 1;
				for ($i = $first_day; $i <= $last_day; $i++)
					$daily_data[$i] = array('topics' => 0, 'posts' => 0, 'user_reg' => 0);
				//free some memory
				unset($first_day);
				unset($last_day);
				//ok get the data now
				//topics
				$sql = 'SELECT topic_time AS time
					FROM ' . TOPICS_TABLE . '
					WHERE topic_visibility = ' . ITEM_APPROVED . '
					AND topic_time >= ' . $start_time[0] . '
					AND topic_time < ' . $end_time[0];
				$result = $this->db->sql_query($sql);
				while ($row = $this->db->sql_fetchrow($result))
					$daily_data[date('j', $row['time'])]['topics']++;
				$this->db->sql_freeresult($result);
				//posts
				$sql = 'SELECT post_time AS time
					FROM ' . POSTS_TABLE . '
					WHERE post_visibility = ' . ITEM_APPROVED . '
					AND post_time >= ' . $start_time[0] . '
					AND post_time < ' . $end_time[0];
					$daily_data[date('j', $row['time'])]['posts']++;
				//user regs
				$sql = 'SELECT user_regdate AS time
					FROM ' . USERS_TABLE . '
					WHERE ' . $this->db->sql_in_set('user_type', array(USER_NORMAL, USER_FOUNDER)) . '
					AND user_regdate >= ' . $start_time[0] . '
					AND user_regdate < ' . $end_time[0];
					$daily_data[date('j', $row['time'])]['user_reg']++;
				//now calculate totals and max
				foreach ($daily_data as $day => $data)
					$totals['topics'] += $data['topics'];
					$totals['posts'] += $data['posts'];
					$totals['user_reg'] += $data['user_reg'];
					if ($data['topics'] > $max['topics'])
						$max['topics'] = $data['topics'];
					if ($data['posts'] > $max['posts'])
						$max['posts'] = $data['posts'];
					if ($data['user_reg'] > $max['user_reg'])
						$max['user_reg'] = $data['user_reg'];
				//now send data to template
				if ($totals['topics'])
					$this->template->assign_var('S_DAILY_TOPICS', true);
						$this->template->assign_block_vars('periodic_topics_row', array(
							'TIME_ELEMENT'	=> date('d F Y', mktime(0, 0, 0, $s_month[0], $day, $s_month[1])),
							'COUNT'			=> $data['topics'],
							'PCT'			=> number_format($data['topics'] / $totals['topics'] * 100, 3),
							'BARWIDTH'		=> number_format($data['topics'] / $max['topics'] * 100, 1),
							'IS_MAX'		=> ($data['topics'] == $max['topics']),
				//posts
				if ($totals['posts'])
					$this->template->assign_var('S_DAILY_POSTS', true);
						$this->template->assign_block_vars('periodic_posts_row', array(
							'COUNT'			=> $data['posts'],
							'PCT'			=> number_format($data['posts'] / $totals['posts'] * 100, 3),
							'BARWIDTH'		=> number_format($data['posts'] / $max['posts'] * 100, 1),
							'IS_MAX'		=> ($data['posts'] == $max['posts']),
				//user regs
				if ($totals['user_reg'])
					$this->template->assign_var('S_DAILY_USER_REGS', true);
						$this->template->assign_block_vars('periodic_user_regs_row', array(
							'COUNT'			=> $data['user_reg'],
							'PCT'			=> number_format($data['user_reg'] / $totals['user_reg'] * 100, 3),
							'BARWIDTH'		=> number_format($data['user_reg'] / $max['user_reg'] * 100, 1),
							'IS_MAX'		=> ($data['user_reg'] == $max['user_reg']),
				//we have to show the month-select box, so get all the months and their display from the board start date
				//calculate the first month and year
				$temp_month = $board_starttime['mon'];
				$temp_year = $board_starttime['year'];
				$month_options = array();
				while (($temp_epoch = mktime(0, 0, 0, $temp_month, 1, $board_starttime['year'])) <= $current_time[0])
					$month_options = array_merge($month_options, array(
						date('n-Y', $temp_epoch) => date('F Y', $temp_epoch)
					$temp_month++;
				$month_select_box = $this->make_select_box($month_options, $s_month[0] . '-' . $s_month[1], 's_month', $this->user->lang['SHOW_STATS_FOR_MONTH'], $this->user->lang['GO'], $this->u_action);
					'TOTAL_TOPICS'			=> $totals['topics'],
					'TOTAL_POSTS'			=> $totals['posts'],
					'TOTAL_USER_REGS'		=> $totals['user_reg'],
					'AVG_TOPICS'			=> number_format($totals['topics'] / $counted_days, 2),
					'AVG_POSTS'				=> number_format($totals['posts'] / $counted_days, 2),
					'AVG_USER_REGS'			=> number_format($totals['user_reg'] / $counted_days, 2),
					'STATS_MONTH_EXPLAIN'	=> sprintf($this->user->lang['STATS_MONTH_EXPLAIN'], $start_time['month'] . ' ' . $start_time['year']),
					'MONTH_SELECT_BOX'		=> $month_select_box,
			break;
			case 'm':
				$show_all = false; //whether to show from the board start date
				//get the year for which to show stats, by default set it to the current month
				$counted_months		= 0;
				if (!$s_year)
					$s_year = $current_time['year'];
				else if ($s_year == 'all')
					$show_all = true;
				//now get the first and last time limit for the search
				$start_time = $end_time = $counted_months = 0;
				if ($show_all)
				else
					if ($s_year == $board_starttime['year']) //if the board started in the selected year, start from the board start month
					else
						$start_time = mktime(0, 0, 0, 1, 1, $s_year);
					if ($s_year == $current_time['year'])
					else
						$end_time = mktime(0, 0, 0, 1, 1, $s_year + 1);
				$monthly_data = array();
				$offset_start_time = $start_time[0];
				while ($offset_start_time < $end_time[0])
					$monthly_data[date('F Y', $offset_start_time)] = array('topics' => 0, 'posts' => 0, 'user_reg' => 0);
					$counted_months++;
					$offset_start_time = mktime(0, 0, 0, $start_time['mon'] + $counted_months, 1, $start_time['year']);
				//now get the queries
				//topics
					WHERE topic_visibility = ' . ITEM_APPROVED;
				if (!$show_all)
					$sql .= ' AND topic_time >= ' . $start_time[0] . ' AND topic_time < ' . $end_time[0];
					$monthly_data[date('F Y', $row['time'])]['topics']++;
				//posts
					WHERE post_visibility = ' . ITEM_APPROVED;
				if (!$show_all)
					$sql .= ' AND post_time >= ' . $start_time[0] . ' AND post_time < ' . $end_time[0];
					$monthly_data[date('F Y', $row['time'])]['posts']++;
				//user regs
					WHERE ' . $this->db->sql_in_set('user_type', array(USER_NORMAL, USER_FOUNDER));
				if (!$show_all)
					$sql .= ' AND user_regdate >= ' . $start_time[0] . ' AND user_regdate < ' . $end_time[0];
					$monthly_data[date('F Y', $row['time'])]['user_reg']++;
				//all data retrieved now get the max and totals
				foreach ($monthly_data as $month => $data)
				//show stats for topics
					$this->template->assign_var('S_MONTHLY_TOPICS', true);
							'TIME_ELEMENT'	=> $month,
				//show stats for posts
					$this->template->assign_var('S_MONTHLY_POSTS', true);
				//show stats for user_reg
					$this->template->assign_var('S_MONTHLY_USER_REGS', true);
				$year_options = array();
				while ((int) $temp_year <= (int) $current_time['year'])
					$year_options = array_merge($year_options, array(
						$temp_year . ' ' => $temp_year //we have to give the space so thats its taken as a string, while receiving the argument at the start of this function, we trim it. I tried converting the number to string but still didn't work!
					$temp_year++;
				//add the extra 'all' option also
					'all' => $this->user->lang['ALL']
				$year_select_box = $this->make_select_box($year_options, ($show_all) ? 'all' : $s_year . ' ', 's_year', $this->user->lang['SHOW_STATS_FOR_YEAR'], $this->user->lang['GO'], $this->u_action);
					'AVG_TOPICS'			=> number_format($totals['topics'] / $counted_months, 2),
					'AVG_POSTS'				=> number_format($totals['posts'] / $counted_months, 2),
					'AVG_USER_REGS'			=> number_format($totals['user_reg'] / $counted_months, 2),
					'STATS_YEAR_EXPLAIN'	=> sprintf($this->user->lang['STATS_YEAR_EXPLAIN'], $start_time['year'] != $current_time['year'] ? ($show_all ? $start_time['year'] . ' - ' . $current_time['year'] : $start_time['year']) : $current_time['year']),
					'MONTH_SELECT_BOX'		=> $year_select_box,
			break;
			case 'y':
				$counted_years		= 0;
				$start_time = getdate($board_starttime[0]);
				$end_time	= $current_time;
				$yearly_data = array();
					$yearly_data[date('Y', $offset_start_time)] = array('topics' => 0, 'posts' => 0, 'user_reg' => 0);
					$counted_years++;
					$offset_start_time = mktime(0, 0, 0, 1, 1, $start_time['year'] + $counted_years);
				//topics
					$yearly_data[date('Y', $row['time'])]['topics']++;
				//posts
					$yearly_data[date('Y', $row['time'])]['posts']++;
				//user regs
					$yearly_data[date('Y', $row['time'])]['user_reg']++;
				foreach ($yearly_data as $year => $data)
					$this->template->assign_var('S_YEARLY_TOPICS', true);
							'TIME_ELEMENT'	=> $year,
					$this->template->assign_var('S_YEARLY_POSTS', true);
					$this->template->assign_var('S_YEARLY_USER_REGS', true);
					'AVG_TOPICS'			=> number_format($totals['topics'] / $counted_years, 2),
					'AVG_POSTS'				=> number_format($totals['posts'] / $counted_years, 2),
					'AVG_USER_REGS'			=> number_format($totals['user_reg'] / $counted_years, 2),
			break;
			default:
			'L_TITLE'		=> $this->user->lang['BASIC_STATS'],
			'U_D_MODE'		=> $this->u_action . '?mode=d',
			'U_M_MODE'		=> $this->u_action . '?mode=m',
			'U_Y_MODE'		=> $this->u_action . '?mode=y',
			'S_FORM_ACTION'	=> $this->u_action . '?mode=' . $mode,
			'AS_ON'			=> sprintf($this->user->lang['AS_ON'], $this->user->format_date($current_time[0])),
		$this->template->set_filenames(array('body' => $mode . '_view.html'));
		$page_title = $this->user->lang['STATISTICS'] . ' &bull; ' . $this->user->lang[strtoupper($mode . '_view')];
		page_header($page_title);
		page_footer();
	private function make_select_box($options, $selected, $select_identifier, $label_prompt, $submit_prompt = 'submit', $action_url = '')
		$return_str = $temp_str = '';
		foreach ($options as $option => $option_lang)
			if ($option != $selected)
				$temp_str .= '<option value="' . $option . "\">$option_lang</option>";
			else
				$temp_str .= '<option value="' . $option . '" selected="selected">' . $option_lang . '</option>';
		$submit_prompt = ucfirst($submit_prompt);
		if ($options)
			$return_str = '<fieldset><label for="' . $select_identifier . '">' . $label_prompt . ': </label><select name=' . $select_identifier . ' id="' . $select_identifier . '">' . $temp_str . '</select> <input class="button2" type="submit" value="' . $submit_prompt . '" /></fieldset>';
		return $return_str;
Clear cache.
Now members can see all statics
BLIZZARDCZ
    Windows 8.1 Firefox
Re: Basic Stats
Post by BLIZZARDCZ »
How do I make an entry to show me the names of the months in my native language? I suppose it is controlled functions php date, but I do not know how to throw it to the Czech language.
Thank you
Blizz
Hippie459MN
Re: Basic Stats
Post by Hippie459MN »
Very nice! Cant believe I am just now finding this. Thank you.
"I went outside once. The graphics sucked but the game play was ok."
f1572238@nwytg.com
Re: Basic Stats
Post by f1572238@nwytg.com »
The sorting looks quite strange:
Re: Basic Stats
My forum was created in 2016. From the old forum (from year 2015) I integrated posts about "Change post time". However, 2015 will now come after 2018 and not before 2016.How can i fix this?
Bye Jan
