3.1.x Extensions Database 3.1 / 3.2Online users avatar
Online users avatar
Extension Name: Online users avatar
Users avatars in online list.
Requested by Razvanel
dmzx/Online-users-avatar
Updated code for no avatar
Online users avatar v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `onlineusersavatar`.
  4. Copy the `onlineusersavatar` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/onlineusersavatar/composer.json
  6. Look for `Online users avatar` under the Disabled Extensions list, and click its `Enable` link.
cov182004
Re: Online users avatar
Post by cov182004 »
Fatal error: Can't use function return value in write context in /home/footb839/public_html/forum/phpBB3/ext/dmzx/onlineusersavatar/event/listener.php on line 68
cov182004
Post by cov182004 »
Tried it on a test forum and get the same Fatal error: Can't use function return value in write context in /home/footb839/public_html/predictions/ext/dmzx/onlineusersavatar/event/listener.php on line 68
What version of phpBB do you use?
cov182004
Post by cov182004 »
PHP Version 5.3.29
bb 3.1,9
all4phone
Post by all4phone »
PHP Version 5.5.35
Works like a charm on 3.1.9 :tumbsyes:
cov182004
Post by cov182004 »
Tried again using the upload tool with the result the same
Razvanel
Post by Razvanel »
cov182004 wrote: 19 Jun 2016, 21:18 tried again using the upload tool with the result the same
Change
if (!empty(phpbb_get_user_avatar($row)))
to
if (!empty($row['user_avatar']))
Ty dmzx
Download updated :wink:
zardos
Post by zardos »
Thankyou dm, great ext. :tumbsyes: :wink:
cov182004
Post by cov182004 »
Working great now :tumbsyes:
pneige
Post by pneige »
Hi Folks
It doesn’t really work for me. Only some standard-avatars are shown, not the real avatars my members have :???: .
pneige wrote: 22 Jun 2016, 19:39 Hi Folks
Can you PM me a test account?
pneige
Post by pneige »
Hi dmzx!
Thanks for your engagement and thanks for your reply. And sorry for my late answer.
dmzx wrote: 23 Jun 2016, 00:10 Can you PM me a test account
Done!
teufel
Post by teufel »
Have problem with onlinavatar see picture here the problem is also but in prosilver
