3.2.x Extensions Database 3.2 / 3.3 ⇒ Welcome on index
Welcome on index
This one should always be at the very top of the page and only on the index.
Re: Welcome on index
If you installed this ext your need to download it again and just install over the one you have stoker left some other ext code in it i have removed it now.
Yup your right it dont work on 3.2 but you can see it working on many 3.2 boards.
How you ask as it dont work.
simples it does work and is in use on many boards.
makis
With all my respect your demo doesn't work either
Dude the ext works and yes it dont on my site as i removed it.
Edit: i just installed it just for you on 3.2
see it not working here http://www.martins.homelinux.net/forum/index.php
makis
Thanks mea culpa I dint notice that in your download folder tree was welcomeonindex/welcomeonindex./ ........
DaSchorse
Hi Guys,
I can not run the extension, in which directory must the folder with the Composer.json file and the other files lie? And does the folder still have to be renamed?
At the moment it is like this:
ext / dmzx / welcomeonindex
but phpbb can not find it like this screenshot.
Can someone tell me what I did?
how u try to install the ext?DaSchorse wrote: 09 Feb 2018, 14:57 Hi Guys,
DaSchorse
On the same way like all other ext.
I upload it to my ext / dmzx directory, but in the acp of my phpbb it is unfortunately not to be activated ext. to find.
what phpbb version is ur forum?DaSchorse wrote: 09 Feb 2018, 15:51 on the same way like all other ext.
u need to create dir on ur ftp with name marting then put there second folder
